RV.Net Open Roads Forum: Tech Issues: Underground 250ft run
 > Underground 250ft run
Page of 8
stevenal
Newport, OR, USA
Posted: 04/02/23 10:38am Link  |  Quote  |  Print  |  Notify Moderator
NM 811 wrote:
Will my private utility lines be marked? No. Member utilities companies are responsible to mark only the facilities that they own or maintain. Private underground pipes and cables may not be owned or maintained by member utility companies, therefore they are unable to locate them. Private utility lines are lines commonly between the meter and a home or utility lines that were installed by the home owner to out buildings, etc. It is your responsibility to investigate if any privately-owned utilities are in the area.
NM 811
To get to your house and meter, utility must run lines on private property. By law, they are responsible for locating them, and you will be liable for repair if you damage them. Beyond the meter is all yours.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
2oldman
NM
Posted: 04/02/23 10:59am Link  |  Quote  |  Print  |  Notify Moderator
stevenal wrote:
private underground pipes and cables may not be owned or maintained by member utility companies, therefore they are unable to locate them.
Unable meaning unwilling. That makes no sense. They will let a homeowner run the risk of digging up a line rather than spend 10 minutes locating it. I'll go out on a limb here and submit it's a liability issue.
* This post was edited 04/02/23 11:08am by 2oldman *
Posted: 04/02/23 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Lol. You’re upset that a public utility company won’t go above and beyond to do favors for every private landowner with their own private utilities that are of no responsibility to nor any control of by the utility company?
ktmrfs
Portland, Oregon
Posted: 04/02/23 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Newer (at least 1978 or later) construction has a tracer wire buried with the utility which makes it easy to trace. Once it hits the end of the utility service, likely no tracker wire which makes it harder to trace. And then copper/galvanized pipe, electrical wires are easier to trace w/o a tracer wire.
2011 Keystone Outback 295RE
rhagfo
Portland, OR
Posted: 04/02/23 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Utility companies are only required to mark location of underground cables to the meter, after that it is private cabling. There are companies that will for a price come out and attempt to locate underground utilities.
ktmrfs
Portland, Oregon
Posted: 04/02/23 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
At least around here 811 is a free service, likely funded by the utility companies and gov't. Purpose is to keep YOU from damaging THEIR utility and then YOU needing to pay for the damage. Saves both parties from possible damages and at a minimum expense to repair. Worst cast injury or death getting across an underground power line.
Whats on YOUR side of the utilities is YOUR repsonsibility and on YOUR dime to locate.
What is interesting in our area is that Sewer becomes your repsonsibility as soon as it hits your property line so all the sewer locate will do is mark from the manhole cover to the street.
* This post was edited 04/03/23 03:33pm by ktmrfs *
way2roll
Wilmington NC
Posted: 04/03/23 06:48am Link  |  Quote  |  Print  |  Notify Moderator
OP has left the building.
2023 FR Sunseeker 2400B MBS
2oldman
NM
Posted: 04/03/23 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
And you're upset that I'm upset. I can always count on you for a smart-aleck answer.
What I don't get is that they post these signs "Call before you dig", but, if they only locate up to private property, that would indicate they only locate in the public right-of-way. Why would I be digging up the public right-of-way?
What am I missing here?
MFL
Midwest
Posted: 04/03/23 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Locating service may be different by region, but in my area, they mark whatever area you plan to dig. Front yard/back yard, public right of way, they cover it all, when you call. No charge for service, but can't speak to damage, for not calling.
Yup, they say "call before you dig", and seem happy that you did.
Jerry
wapiticountry
Mountain West
Posted: 04/03/23 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Anytime I had locates they marked to the service entry points. That would be to the meter for water electric and gas and to the junction box on the house for cable and phone. Past wthose points it was on my dime to contract with a locate service to mark any underground lines since those are technically my responsibility.
Page of 8
