RV.Net Open Roads Forum: Fresh water tank location in 1999 Windsor class A motorhome
 > Fresh water tank location in 1999 Windsor class A motorhome
Meta_A
98903
Posted: 04/03/23 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I hope this is where I can post this question.
I just filled the fresh water tank on this motorhome I just bought. From my estimation it held a good 70 gallons if not more.
However I for the life of me can not find this huge tank as to its location.
I can't wrap my head around it as to exactly where this beast is.
Yes I have the manual. It only has a diagram which means nothing. It does not show exactly where it is located. It just shows the typical basic design of the system.
The rig is a good 30 feet long. I wonder if anyone else has this motorhome and might know where the fresh water tank maybe. I have called around and no luck.
Thank you.
* This post was edited 04/04/23 01:03pm by an administrator/moderator *
cekkk
Southern Nevada
Posted: 04/03/23 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
While this form is called helping support, it's misleading. It is for technical support regarding the form itself. You need to look under the various. Forms available and choose motor homes.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
craig7h
Branson MO area
Posted: 04/04/23 02:51am Link  |  Quote  |  Print  |  Notify Moderator
As much as I hate to send folks to different forums! It may benefit you to try irv2. Due to the age of your unit you should find some good information there. Go to owners forums then to Monaco.
Other than just wanting to know was there are reason why you needed tank location. Designer's are really crafty on how they put things between frame work. Figure the fuel tank, fresh water, grey water, black water. all have large tanks that have to be placed between the frame work.
Good Luck safe travels
Itasca Meridian SE 36g
Road Master Tow Dolly
midnightsadie
ohio
Posted: 04/04/23 05:02am Link  |  Quote  |  Print  |  Notify Moderator
so get on the ground and crawl under the rig bet its there.
Bruce Brown
Northern NY
Posted: 04/04/23 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Is it a gas or diesel? What floorplan?
If it's a diesel it's behind the peg board in the compartment by the back wheel. You can normally see it from the fill side if you duck down and look behind the panel.
If it's a gasser it should be in the back somewhere.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
zigzagrv
Nazareth, PA
Posted: 04/04/23 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Take a look under the bed.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
ferndaleflyer
everywhere
Posted: 04/04/23 08:10am Link  |  Quote  |  Print  |  Notify Moderator
So far you have got no information as to your question. I have a Monaco Windsor if thats the Windsor you are referring to and the fresh tank is behind the area where the dump valves are for the grey and black tanks. The bottom of this unit is completely sealed so you can't see by looking under it from underneath. The motor is under the bed!
Executive45
Posted: 04/04/23 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Simplest way is to go to the fill valve and follow the tube to the tank....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Posted: 04/04/23 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Ok on MOST (Alas not all) motor home look for a square door about on 6-8" square with rounded corners and a lock... Open them and look
Under one of them will be a white plastic cap and often a small vent hole near it.
That's the gravity feed to the fresh water tank (Cap is about 1 inch ID or 1.5 OD)
Follow the hose down to the tank.
ferndaleflyer
everywhere
Posted: 04/04/23 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
There is no way to fill the fresh water tank on my Monaco Windsor other than hook a hose to the fill valve location in the wet bay. Also no door with a lock etc.
Glad to see you back in here Dennis--was wondering about you.
