RV.Net Open Roads Forum: Tow Vehicles: RAM EV
Search only in Tow Vehicles
 > RAM EV
Page of 6
Reisender
NA
Posted: 04/14/23 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Golden_HVAC wrote:
FishOnOne wrote:
Without detailed specifics, RAM is essentially saying all your EV truck concerns (Specific shot at the F150 Lightning) will be a non issue with their EV truck. This truck maybe so good it's forcing Ford's hand to redesign their Lightning already.
It takes Ford 5 years to go from a design to produce the tooling to install that tooling in a factory to actual production of a new vehicle. So if the 2025 F-150 EV is coming out in September of 2024, then 5 year before (September of 2019) is when Ford decided what it will look like and started to change the design from a computer drawing into the tooling they need to produce the truck.
By January of 2021, Ford knew what the 2025 F-150 looks like and has the tool and die makers producing that stuff. Ford could make a minor change, such as changing from a 130 to a 150 KW battery pack at this point, but by the spring of 2024, it will be to late to make such a change. And they want something new to put into the 2026 model refresh, so they might not want to start out with a 150 KW battery option until the 2026 model year update.
Ram is making a ridiculous 190 and optional 230 KW battery pack. By using 8 bolt rims, it seems to have a over 8,500 GVWR, so the highest of all the Big 3 at this point. Towing a fifth wheel is actually going to be possible. With the battery cell cost of about $150 per KW, that is about $15,000 for the 100 KW battery pack, twice as much for this size truck, no wonder they will not give out the total price! Maybe RAM is hoping that the price of batteries will drop below $100 per KW by 2025.
People towing with a Rivian and Lightning are getting about 1/2 of the rated mileage when not towing. So the 500 mile range, if they actually reach that, expect about 200 - 250 miles while towing a travel trailer that is lower profile, and a little less in a fifth wheel that is taller and more wind! That is still acceptable, as your can charge it very quickly because it is 800 volt battery, and can get about 200 amps X 800 volts or 160 KW into the battery - so a 30 - 45 minute charge will fill it a lot.
I think that most cars are currently limited to 400 volts from the charger, and the power cord is limited to only about 300 amps maximum.
The RAM has some great specs. I just wish they had come up with the design before 2020. And could have it in production by the end of 2023. But as the superbowl ad says "We do not want premature electrification".
I also think Ford thought the EV F-150 would not be popular, and that only 10,000 a year might be sold, and might end up collecting dust on the parking lots. Where they wrong with that prediction!
Lets hope that Ford has a heavy duty F-250 EV truck planned for 2026! I think they will need it!
Fred.
Hi Fred. Yah. The majority of EV’s are 400 volt architecture and peak out at 250 kw (although we briefly see 254 or 256 for the first minute or two when below 20 percent charge). There are a few manufacturers with 800 volt architecture but although they theoretically can charge at 350 kw they are presently peaking out at 270 kw. 350 kw chargers are not really super common out there either. Electrify America and Electrify Canada put in some 350 kw machines (typically 1 out of 4) and the new Tesla V4 installations will all be 350 kw machines. But presently not a ton of 350 kw machines out there.
The cyber truck is going to be an anomaly. It can apparently charge on the new tesla megachargers which are 750 kw to 1000 kw machines. But they are presently only found at private truck depots that use tesla semis. Unknown what speed they charge at although it’s at least 350 kw and rumour says 500 kw. Rumour also says the largest Cybertruck battery pack is 180 kWh. The aerodynamics will probably allow it to go pretty far though. Time will tell.
Cheers.
vern kelly
la crescenta, ca
Posted: 04/15/23 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Added curb weight is a big problem for trucks because it robs payload, to stay within acceptable Gross Vehicle weight ratings which in turn affect registration fees and insurance price.
example: what happens when the EV truck rear ends the Cooper Mini with that extra 1 to 1.5K!
I goofed on the F350 Dually payload. its over 7K for the 2wd. Over 4K for the SWR version. Sorry about that!
* This post was edited 04/15/23 10:33pm by vern kelly *
1998 2500 Dodge V10 3.55 Quad cab. Lance 5000 camper 9'10" and tow 17.5 ft Larson Boat
NamMedevac 70
Reno
Posted: 04/15/23 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
well said Vern Kelly.
On another note I miss my 2008 2500 Dodge Ram V10. However my 2014 Ram 1500 with 5.7Hemi has about same HP and torque ratings, so everything good to go. Owned 4 Ram trucks and now there are 3.
vern kelly
la crescenta, ca
Posted: 04/15/23 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
But the torque is not not 400 foot pound at a measly 1500 RPMs with 450 at 2500! Now that is a long stroke gasser! The Hemi is great, towed horse trailers with one and had a direct comparison with mine. The transmission was fantastic too! The cummins diesel was the best though (2016) and loved the exhaust braking and auto leveling feature.
Hope their EV version competes with Ford despite all the issues.
Reisender
NA
Posted: 04/16/23 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Good morning. I think it will. More specifically it will probably exceed the existing first generation ford lightning.
But in 2025 for us set to release the second generation lightning. There hasn’t been a lot of leaks on specs but my guess is it will be a significant step up. And they will probably have ramped production significantly by then….if they can get enough batteries.
Should be interesting. The Ram EV shape is growing on me. I would like to see an aerodynamic coMparison of it and the Cybertruck.
Cheers.
pianotuna
Regina, SK, Canada
Posted: 04/16/23 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I happened to go to the CAA site today and clicked on a link for BEV's available for sale in Canada. I was pleasantly surprised to see over 100 different vehicles.
The lowest price was 39,498 cdn. Cheapest was the Leaf, and next in line was the Bolt EV LT @ 40,797
Regards, Don
CWilson
Beach
Posted: 04/16/23 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Goody!
You can get a Kia Soul EV Premium for 43,095 cdn.
You can also get a Kia Soul EX Premium with the ICE for 29,733 cdn.
If you want to pay 31% more to have an Electric powertrain have at it.
BTW the website you reference is not accurate, A Kia Soul EV Premium starts at 45,933 cdn, not the 43,095 the website states. And a Bolt or Leaf starts out at more than the website states also.
pianotuna
Regina, SK, Canada
Posted: 04/16/23 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
CWilson,
Thanks for the information.
Goody that you wish to pollute the planet, while the oil companies make billions of dollars while being subsidized by the government.
wing_zealot
East of the Mississippi
Posted: 04/17/23 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Net Zero and don't pay taxes? Never met anyoone that fit that description before.
Posted: 04/17/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
CWilson,
Mmmmkay…
* This post was edited 04/17/23 01:19pm by Grit dog *
Page of 6
 > RAM EV
