RV.Net Open Roads Forum: Didn't Think Much of These - Screws Under Vinyl Insert Trim
 > Didn't Think Much of These - Screws Under Vinyl Insert Trim
Powertour
Nevada
Posted: 04/06/23 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Long story short. Vinyl insert trim on my RV was finally looking rough enough for me to start replacing it. Upon starting the job I noticed a number of the screws the trim is there to protect were loose & in a few places there were never any installed during the rig's manufacture.
For those of you that have RVs that live in wet climates it's probably a good idea to check out the seam screws under your insert trim to ensure they're there & snugged up (if not re-sealed).
2015 Itasca 25b Ford E350 V10
MNtundraRet
Bloomington, MN
Posted: 04/06/23 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Someone messed up when your MH was made.
However, unless there is an obvious problem it isn't worth removing good vinyl trim to look for a problem that may not be there.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
Powertour
Nevada
Posted: 04/06/23 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Agree. 100% not advocating people remove good vinyl to check for loose or missing screws. I'm advocating not procrastinating (like I did) on replacing old UV-hammered stuff as it's dirt cheap to purchase & you could very well find the things I did.
Doesn't one or more people mess up during every single RV build? I'd say LoL but it's not funny what the RV industry has gotten away with for eons now.
dedmiston
Coast to Coast
Administrator
Posted: 04/07/23 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
This should be printed right below the RVIA sticker on the side of every new coach.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Lumpty
Greater Gotham City
Posted: 04/07/23 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
All the screws were there when I replaced that vinyl trim on my Class C a couple of years ago. The problem was that while the trim was in OK condition, the motorhome had been built in July in the heat of the summer, and the trim pulled super tight before being screwed in at each end. Every winter in the cold northeast it shrank and pulled out of the track. As it got older, what little elasticity it had got less and less, and eventually it just wouldn’t stay in. This led to a couple of times it completely coming out of the track while driving, coincidentally each occasion being in busy conditions on I-294 going around Chicago. Fun times to pull over and pop it back in by hand.
When I replaced both sides, I did it in 50-55 degree weather, and did not stretch it at all. Holding up fine. The original install was yet another example of the fine workmanship we’ve all experienced.
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
MNtundraRet
Bloomington, MN
Posted: 04/08/23 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Maybe I should have mentioned that the Hi-Low we purchased in 1984 had screws come loose on the rails the upper shell rises on. The lowest one caused a problem when we went to raise the shell. I ended up recrewing all screws using "Loctite".
I would call the one a design problem since this can easily happen in a stste like Minnesota with extreme temperature changes. I fixed the problem about 2 years after we got it. We traded the trailer in 1999.
* This post was edited 04/08/23 10:17am by MNtundraRet *
valhalla360
No paticular place.
Posted: 04/09/23 12:24am Link  |  Quote  |  Print  |  Notify Moderator
Are you speaking of the 1inch wide strip that squeezes into the metal near the joints?
If yes, you can check by simply running your finger down it. You can feel the screws underneath (or not). If it's relatively new, not a big deal to pull it out and then put it back in. Did that on our latest when I found a couple screws that weren't all the way in.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Gjac
Milford, CT
Posted: 04/10/23 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
When I pulled my trim off, I found a number of screws rusted badly some almost completely in half and a few with just the heads in tack. They were not SS.
Powertour
Nevada
Posted: 04/13/23 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes & understand what you're saying... in certain conditions. The vinyl was so heat pummeled on my rig that it was about rock hard in the majority of places. There were a couple of spots near the roofline trim section that I could see where screws had back out enough to be poking the trim outward. Most of the loose stuff I found however, wasn't backed out near that far. Nonetheless I'm happy I did this job (it needed it).
C Schomer
Pueblo West, Co.
Posted: 04/15/23 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I ran into that on a forest river fiver. In a row of 45 screws 15 of them twisted off about two threads from the heads. The heads were there, but water was leaking through the gap that was left by the broken screws. I got all of the screws out, including the broken ones, shot caulk into the gap, and re-screwed that entire length.
I prefer to find those boo-boos and fix them right. Craig.
