RV.Net Open Roads Forum: General RVing Issues: Rodent repellant
 > Rodent repellant
Goostoff
Wisconsin
Posted: 04/08/23 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Just opened up the trailer this morning from its long winter nap to check things over and start getting ready for camping season. I found one single mouse turd in a drawer. I have tried all of the gimmicks over the years in the boat and camper. Always found the best thing was just good ole Bounce dryer sheets. For the last 3 years I have been also using a product called Grandpa Gus's Mouse Pouches in addition to my dryer sheets and noticed that we didnt have any mouse **** at all. Last fall I decided to just use the mouse pouches. Same results. one single little turd is a victory to me.
To give a little background my trailer is parked on a farm right by a machine shed full of farming equipment including a feed grinding mill, so mice and rats are a staple of the area.
I have no affiliation to this company. Just thought I may be able to help out fellow RVers
1993 Chevy C3500
2005 Cedar Creek 34RLTS
midnightsadie
ohio
Posted: 04/08/23 09:32am Link  |  Quote  |  Print  |  Notify Moderator
well mine sits in about the same area. BUT I use peppermint oil drops all around and inside not a mouse about ten years now. boat same way. I do set traps with peanut butter out side about ten/twenty food away. farmers out west use this ,most there machines set under open buildings. but theres no true thing that works.
Wadcutter
IL
Posted: 04/08/23 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Hedge apples. Keeps mice and spiders away.
Place a few in something like 1 gal milk jugs. Set several around inside and in the basement.
The hedge apples will soften and begin to rot during the winter with the freezing and thawing so the need to put them in something like plastic jugs. But when they soften and start rotting they put off a sweet smell which not only keeps the critters away but gives the camper a nice smell.
I'm in the country where crops are all around the house and camper. Hedge apples have worked for years keeping critters out.
Camped in every state
Goostoff
Wisconsin
Posted: 04/08/23 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
We tried the peppermint oil a few years ago and had the worst year ever so we never tried it again. We tried the hedge apple in our basement once a long time ago to try getting rid of spiders and they just built webs right on top of them. LOL
midnightsadie
ohio
Posted: 04/08/23 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
wis tuff state home of the 3 inch mosquito.lol I use real peppermint oil.
JimK-NY
NY
Posted: 04/08/23 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Isn't the best solution to find the points of entry? There should be none in a well built RV but at the worst there should only be a very few possibilities.
Goostoff
Wisconsin
Posted: 04/08/23 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
We have stuffed every crevice we can find with steel wool. Our sliding door for the bedroom has wires going down through the far back of it right into the basement area. I cant find a way to get to it without damange and thats where i think they come in.
MitchF150
Puyallup, WA
Posted: 04/08/23 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
What JimK said.. I've parked my TT's in the same spot for 20 years now. I have a firewood shed right behind it on the side of my house. I put rat bait in the firewood shed all the time, and find the remnants of them all the time. In addition to all the turds and chewed bits of firewood so I know the area has rats/mice present.
To date, I have never had one in a TT. I have never placed any kind of deterrent in the TT either.
Only thing I have done is make sure there are no points of entry from the outside of the trailer. Especially the under side.
Even the smallest of cracks or gap can let the little varmints in. On the first trailer, I did seal up some very small gaps with silicon sealer. On the current trailer, I've not had to do anything to it. I did inspect it when I first got it of course. That meant crawling on my back under the whole underbelly. This one is a 'sealed' underbelly, but it looked like the manufacture took care of any cracks/gaps before I got it. [emoticon]
Anyway, I'd be doing a close check on the underbelly and seal up any cracks/gaps before using any of the so called "repellants".
On a side note, I have heard a lot of folks say all they do with the dryer sheets is make a bed with them.. [emoticon]
Wood shed is in background.
Good luck! Mitch
Wiscampsin
Wisconsin USA
Posted: 04/08/23 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Steal wool will rust in time and break down. For this reason I use stainless steel wool. Found it at WalMart by the kitchen sponges. Be careful, it's sharp.
MitchF150
Puyallup, WA
Posted: 04/08/23 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
I must have been typing my reply when you sent this one.
Sounds like you have a 5th wheel. My folks had a 5th wheel that they stored in a covered shop, and they always had mice in it.. He did try to seal up too, but like you say, there are just too many points of entry in that basement area I guess...
Well, good luck with it all the same! I feel for ya!
Mitch
 > Rodent repellant
