RV.Net Open Roads Forum: Technology Corner: Removing AM24N tuner from DirecTV satellite receiver
 > Removing AM24N tuner from DirecTV satellite receiver
Posted: 04/09/23 07:07am Link  |  Quote  |  Print  |  Notify Moderator
If the device is optional then there are two sets of what are called Binary files (BIN) for your receier. the other name (more proper) is Firmware or software (Depending on how the receiver stores it) you need the proper version of the "Ware".
Or there is a menu setting but don't ask me where.
mikestock
Vestavia Hills, AL, USA
Posted: 04/09/23 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
rk911 wrote:
old tech. really not surprising. why not just re-insert the device?
I'm just trying to streamline my shelves and eliminate unnecessary wiring. If I wanted to keep the old, unused box on my shelf I would not have posted the original subject.
mikestock
Posted: 04/09/23 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I'm looking for. It doesn't surprise me that their Tech Support never heard of the AM24N.
mikestock
Posted: 04/09/23 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
If the receiver is also NOT a DVR I would suggest that you do a factory reset with the tuner not installed. It should put you back to where the receiver was before you installed the tuner.
I would, except I am concerned that I may awaken some unforeseen problem. I am close to ditching the dish, anyway. I kind of hate that I've spent so much money on the automatic dish and other equipment to make the dish work.
LouLawrence
Traveling the US fulltime since 2000.
Posted: 04/10/23 08:18am Link  |  Quote  |  Print  |  Notify Moderator
If your automatic antenna is a Winegard the tuners condition will not effect it in any way. I use the Trav'ler with DirecTV and have done the factory reset a couple of times without issue. If the message really bothers you it's likely your best choice. The receivers are intentional setup so you can screw with the programming.
mikestock
Posted: 04/23/23 09:47am Link  |  Quote  |  Print  |  Notify Moderator
That's the big question. I could probably do a hard reset of the receiver. I think that's #981 but you lose all your recordings on that receiver.
