neu
Toronto
Yes, it is still humming...
The new one cost CAD $229.00 (Danby 5,000 BTU Window Air Conditioner) in the Home Depot. So I am considering buying a new one, but another tricky question is how to unmount the current. I've looked around today, and I have no idea how they mounted it at the factory. Everything is hidden inside the cabinet
schlep1967
Harrisburg, PA
That hum is definitely a locked compressor. It would sound the same if it was running and you turned it off and right back on without waiting a few minutes. It may work when it gets warmed up. Then again, it might not.
As for access, it looks like it was put in from the rear since the flange is behind the cabinetry. Look for accessible screws to remove a panel nearby, behind it, beside it or below it. Unless that whole front panel is removable...
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
