RV.Net Open Roads Forum: Missing orange cover on marker light; Water leakage concerns
 > Missing orange cover on marker light; Water leakage concerns
greenno
Clairemont Cal.
Posted: 04/11/23 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Brother go to e-trailer.com or Amazon and type in "Plastic side marker lights" you'll get a bunch of hits
shum02
Burlington ON CDA
Posted: 04/12/23 04:15am Link  |  Quote  |  Print  |  Notify Moderator
You're Canadian. Learn about this retailer.
Princess Auto. Pick them up for a few dollars. Regular or LED
* This post was edited 04/12/23 01:25pm by shum02 *
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Chum lee
Albuquerque, NM
Posted: 04/12/23 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Google "Bargman marker lights" They won't be an exact replacement but between the hundreds of options available, I'm sure you'll find something acceptable which has better quality than what you currently have. Just buy the entire fixture (with the bulb holder/wiring) rather a replacement lens.
Check your other marker lights for cracks/water leakage. You may want to replace those too.
Chum lee
fourthclassC
MA
Posted: 04/20/23 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Grote makes a great line of marker lights, including LED's .
opnspaces
San Diego Ca
Posted: 04/20/23 09:32am Link  |  Quote  |  Print  |  Notify Moderator
I just went through this exact thing on my trailer. Take a wet towel can clean the dirt out if the light base. I can see a number embossed in the attached picture but I can't quite make it out. If there is a manufacturer name try searching for that too.
But take that number and type it into Amazon and see if it gets any hits. Also try a google search of the number + marker light and see if you get any hits.
Mine was from 2005 so it probably wouldn't work for you but here it is just in case.
Amazon
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Roger10378
Goodrich, MI.
Posted: 04/20/23 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
I looks a lot like the ones on my 2005. Mine is marked Bargman 59. The number is molded in on the outside. I think per DOT the number has to be on the lens.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
