RV.Net Open Roads Forum: Tech Issues: Need Solar Guru Help!
 > Need Solar Guru Help!
Page of 5
campermama
Here and There
Posted: 04/12/23 10:14am Link  |  Print  |  Notify Moderator
This is my system...
570w solar panels (parallel)
?2 100ah BB lithium (parallel) (12v)
Victron smartsar 100/50 controller
Renogy battery monitor
Renogy 2000w inverter
Victron goes through bulk mode until it reaches absorption V, then goes to absorption mode for 1 hr (recommended by BB), (highest V I have seen on the monitor during absorption mode is 13.5, while mppt reads 14.4)then it goes to float (mppt reads 13.6v, monitor reads 13.4v), the amps never go down to 0, it sticks around at 2-4 amps. So to me it seems batteries are never "fully" charged?
V always drops to 13.2(something) v when it gets dark. According to charts I have seen that is only 70%!
ALSO, discharging amps at night seem really low....TV, inverter on, led lights on, it shows - 1.8 amps, how can that be?
Here is a "drawing" of my set up....
My 12v System
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
2oldman
NM
Posted: 04/12/23 10:58am Link  |  Print  |  Notify Moderator
The 1.8 amps sounds more like the 120v side. 13.2 is more than 70% on any chart I've seen. I did not know any Li battery needed absorption.
Boon Docker
Posted: 04/12/23 11:04am Link  |  Print  |  Notify Moderator
Rotated OP's 12v system link.
otrfun
On The Road
Posted: 04/12/23 11:34am Link  |  Print  |  Notify Moderator
I'd suggest checking/verifying load/discharge (-) and charge (+) current separately by measuring current on the appropriate wires/cables with a DC clamp-on ammeter (during the day and at night). Your battery monitor only provides the sum total of both, which doesn't give you a clear picture of what's going on. It's also possible your battery monitor is inaccurate or mis-calibrated. A DC clamp-on ammeter would help confirm the accuracy of the battery monitor's current readings.
campermama
Here and There
Posted: 04/12/23 11:41am Link  |  Print  |  Notify Moderator
So there was one connection wrong that was affecting the amps reading....the Neg of the inverter was not on the shunt! I have now switched them.
Now it's just the charge issue, I think.
campermama
Here and There
Posted: 04/12/23 11:44am Link  |  Print  |  Notify Moderator
Can you please post a chart that shows 13.2v is not 70% for Lithium batteries? If it's not 70% what is it?
See my post above this one, I found/fixed an issue that should fix the amps issue.
2oldman
NM
Posted: 04/12/23 12:45pm Link  |  Print  |  Notify Moderator
13.3 to 13.4 is 100%, so I guess 13.2 could be 70%, but that does surprise me.
campermama
Here and There
Posted: 04/12/23 01:00pm Link  |  Print  |  Notify Moderator
Yup, can't figure out why it's that low!
otrfun
On The Road
Posted: 04/12/23 01:03pm Link  |  Print  |  Notify Moderator
campermama wrote:
Can you please post a chart that shows 13.2v is not 70% for Lithium batteries? If it's not 70% what is it? . . .
Many 12v lifepo4 voltage/SOC charts show 13.20v (resting voltage) as equivalent to 70% SOC. The key here is "resting voltage".
If you're going to use a lifepo4 voltage/SOC chart to determine SOC, you must have zero charge/discharge current (ideally by disconnecting the battery entirely). Then you must let the voltage stabilize to a final resting voltage before taking a voltage reading. Depending on the situation, it can take anywhere from a few minutes to a few days to reach the final resting voltage.
As for 2oldman's comment about lifepo4's not needing absorption---that was the lifepo4 charging philosophy a 2-3 years ago when nearly all lifepo4 converters/chargers were single-stage 14.6v (no absorption or float stage). These days it's common knowledge you can damage a lifepo4 subjecting it to a 14.6v bulk mode indefinitely. Thus, the need for an absorption voltage. Many recommend 13.2v - 13.6v. There are still a lot of single-stage 14.6v lifepo4 converter/chargers on the market. Highly recommend purchasing a 2-3 stage converter/charger instead.
2oldman
NM
Posted: 04/12/23 01:24pm Link  |  Print  |  Notify Moderator
Okay, I guess things have changed. My 5yo 48v pack only has bulk and float, but the specs for 12v Battleborns do specify an absorb voltage. I adjusted my solar controller's absorb to almost nothing.
Page of 5
