RV.Net Open Roads Forum: Tech Issues: Need Solar Guru Help!
 > Need Solar Guru Help!
Page of 5
campermama
Here and There
Posted: 04/12/23 04:38pm Link  |  Print  |  Notify Moderator
3 tons wrote:
Make sure the rotary selector switch on your charge controller set to position #7…
3 tons
Not using rotary switch, the setting are not what BB recommends so using user settings
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
otrfun
On The Road
Posted: 04/12/23 04:46pm Link  |  Print  |  Notify Moderator
2oldman wrote:
otrfun wrote:
lifepo4's not needing absorption---that was the lifepo4 charging philosophy a 2-3 years ago when nearly all lifepo4 converters/chargers were single-stage 14.6v (no absorption or float stage).
Also interesting is the 48v Dakota charger appears to have bulk only, so perhaps it depends on the kind of Li battery. But, I'm getting off the subject.
Very possible. Many times manufacturers will recommend different operational specs based on a battery's specific application.
More to my point . . . if a standard lifepo4 (lithium iron phosphate) cell (with a typical 2.5v LVD and 3.65v HVD) is used by a battery manufacturer, and the manufacturer recommends only bulk charging at 14.6v, I assure you they're recommending this at the expense of cycle life. Charging a lifepo4 cell at 3.65v (Maximum Rated Charge Voltage), or a 12v lifepo4 battery at 14.6v, 24/7/365, will reduce cycle life short-term, and permanently damage the cell/battery long-term.
otrfun
On The Road
Posted: 04/12/23 05:25pm Link  |  Print  |  Notify Moderator
campermama wrote:
That's what i am looking at at night, a shunt monitor. I don't need/want to calculate SOC based on V. I'm just looking at what the monitor is telling me and trying to figure out why it's reading 13.2v instead of 13.3 or 13.4 after charging all day.
I assume all the voltage and current readings you're referencing were taken from the battery monitor display and/or Victron controller?
Me, I'd verify charge current (mid-day sun with max charge current) at the battery terminal (before the shunt if measuring at the neg terminal) with a DC clamp-on ammeter. I'd also verify battery charge voltage (mid-day sun with max charge current) at the battery terminal (before the shunt if measuring at the neg terminal) with a voltmeter.
I'd make the same voltage/current checks while doing a high c discharge with your inverter, too.
Do these readings correspond with the voltage/current readings on your monitor (charge and discharge) and/or controller (charge only)?
Did you program your Victron controller with any specific charge profile or voltage(s)?
campermama
Here and There
Posted: 04/12/23 05:34pm Link  |  Print  |  Notify Moderator
Don't have a clamp on meter, mppt programmed to BB recommendations
otrfun
On The Road
Posted: 04/12/23 05:46pm Link  |  Print  |  Notify Moderator
That's too bad. It's very hard to properly troubleshoot a system like yours without a DC clamp-on ammeter. Good luck.
campermama
Here and There
Posted: 04/12/23 06:08pm Link  |  Print  |  Notify Moderator
Just looking for any ideas you guys may have as to what could possibly cause my issue.
campermama
Here and There
Posted: 04/12/23 06:36pm Link  |  Print  |  Notify Moderator
Sorry I don't have the right tools for you to help me. I will purchase one when I am somewhere where I can get one. I'm currently on the road. Thanks anyway.
otrfun
On The Road
Posted: 04/12/23 07:45pm Link  |  Print  |  Notify Moderator
You're welcome. No apologies necessary. Do what works best for you. Be safe!
CA Traveler
The Western States
Posted: 04/12/23 08:10pm Link  |  Print  |  Notify Moderator
WAG The 0.9V drop from your MPPT to the monitor/battery results in the batteries not being fully charged and resutls in the 4.5A monitor reading which is the best charging it can do given the voltage drop.
Also suggest you check your 3x panel Voc vs the 100V MPPT input and see if you can connect the panels in series.
2014 Grand Cherokee Overland
Bob
3 tons
NV.
Posted: 04/12/23 08:58pm Link  |  Print  |  Notify Moderator
campermama wrote:
3 tons
Well I find that rather odd since I live near by and was at BattkeBorn when they handed me my victron charge controller and they’d advance pre-programmed it for exactly what the Victron user manual called for, and mine works perfectly - it must depend on which day of the week you speak to the BB fella’s - I donno?…
3 tons
Page of 5
