dougrainer
Carrolton, Texas
https://www.rvupgradestore.com/Kwikee-Electric-Step-Repair-Kit-p/44-8127.htm
For a step 15 years old, I would purchase the upgrade kit, rather than spend money on individual parts. If you drop the motor, you will probably find the large internal gear inside the gear box has a busted tooth. THAT part they do not sell individually. Yes, the motor stops from the rise in amp draw the controller senses when the step stops moving. Doug
RLS7201
Correct, the gear does not come individually. It comes with the 3 cushions.
Gear
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
dougrainer
Carrolton, Texas
RLS7201 wrote: Correct, the gear does not come individually. It comes with the 3 cushions.
Gear
Richard
Thanks. That is a alternate source. Not Kwikee(LCI). Was not available a few years ago. For $16, safe bet to try. Doug
MrWizard
Traveling
On the steps i have repaired, To visually inspect the gears, you have to remove the motor assembly & swing arm drive box assembly, and open the swing arm box assembly, or at least stick a screwdriver into the slot of the assembly input shaft, and turn it back and forth to each end of travel movement and feel for the stopping or gear rattle as it keeps spinning, is that what you did ?
Looking at the swing arm on the exterior of assembly will not tell you the condition of the gears, the motor assembly has gears, and the swing arm box has gears, and all are hidden from sight, when the motor assembly is removed from the swing arm gear box , the output shaft will spin continuously when power is applied to the motor ,
The swing arm gear box has limited motion, the output shaft of the motor assembly is a slotted fit into swing arm box assembly, a small gear in the assembly meshes with the larger shaped 90° gear which rotates the shaft the swing arm is attached too, this where the break occurs, missing teeth on the 90° partial gear at the full retract position, and you get the rattle and motor spin at the top of retract, if teeth on the little full circle input gear, wear or break, you will also hear a skip bump while the step is retracting,
The fix, is a New swing arm assembly box,
The plastic gears break when under an impact stress, this can mean less damage to the step assembly and a less costly repair,
If the step operates normally when being extended, its a near 100% probability of damaged gears in the swing arm box,
The large limited motion gear is actually a bit more than 90° but a lot less than a half circle 180° gear that one would expect to find inside, calling it 90° is just easier
last
edited 04/25/23 04:17pm by MrWizard *
View edit history
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
MrWizard
Traveling
I do believe i let my old age catch up with me, and confused two different gear Assemblies, i talked about a 90+ degree shaped gear when i
When i should have been talking about a circular gear, but other wise correct , broken teeth cause the non stop motor run on, and the noise , replacing the swing arm gear box assembly, gives the best results, all new parts and bushings with no wear that give it back the like New smoothness of action
Chum lee
Albuquerque, NM
dougrainer wrote: RLS7201 wrote: Correct, the gear does not come individually. It comes with the 3 cushions.
Gear
Richard
Yes. When I repaired my 1999 Series 32 steps that had similar issues (with an upgrade kit) in 2015, that gear was not available, and, believe me, I looked. It wouldn't have helped me anyway because the large die cast metal reduction gear inside the main gearbox is what exploded on mine. I do mean exploded. It was in five pieces inside the gearbox and the steps swung freely in the air. They would not extend or retract fully.
IMO, if your broken Kwikee stairs are +15 years old, replacing one gear in the drive train makes as much sense as replacing 1 broken link in an old worn out bike chain.
Chum lee
dougrainer
Carrolton, Texas
Chum lee wrote: dougrainer wrote: RLS7201 wrote: Correct, the gear does not come individually. It comes with the 3 cushions.
Gear
Richard
Chum lee
As a Professional RV tech, these forums help me find obscure parts that are not easily found on RV part supply systems. Finding these type parts help me save customers money. Doug
