Jspool
Port Orchard, WA
I am going to mount an Onan P4500i generator on a tongue mounted platform on my Cougar 22MLS trailer. I do not readily see an easy way to do this. I have a generator box and four vibration isolating mounts to mountbit with. Has anyon already done this that can help with a suggestion?
Thanks
wanderingbob
monticeeo, fla
Not that generator , not that TT but I have twice mounted gens on the tongue ,. Got 2x2 angle at Tractor Supply , had a welder fasten the angle in correct position to set the generator feet into . Never used isolating mounts , vibration was not a problem .I bolted it down and also added a motorcycle security lock .
Lantley
Ellicott City, Maryland
This is an old post of mine. My last TT had a 4300 Is Robin Subaru genset ted on the rear
Rear Genset post scroll down
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
