RV.Net Open Roads Forum: Tech Issues: gas fridge
 > gas fridge
larrypac
maine
Posted: 04/14/23 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have a gas fridge that is probably 30 or 40 years old. I had gotten so I had to hold in the starter button for 2-3 minutes before flame would stay lit. I pulled it out to se if maybe the thermo couple? was dirty and found that a piece has dropped out of the tube above the flame. I'm attaching pix of the burner area as well as the entire back of the fridge. (COULD NOT FIND A WAY TO ATTACH PIX) Any advice would be appreciated.
* This post was edited 04/14/23 02:25pm by larrypac *
Boon Docker
Posted: 04/14/23 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
How to attach photo - see below
http://photoposting.is-great.net/?i=3
* This post was edited 04/14/23 05:51pm by Boon Docker *
John Wayne
Long Beach, Ca
Posted: 04/14/23 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
no picture seen but if it has a spiral shape to it it should have a hook at the top so it hangs from the top of the chimney that it is inside of.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
larrypac
maine
Posted: 04/15/23 04:12am Link  |  Quote  |  Print  |  Notify Moderator
I would describe the shape as: Take a cross (or an X) and pull it up into 3 dimensional. I can't see the top of it but if it had a hook, it probably rusted off.
dougrainer
Carrolton, Texas
Posted: 04/15/23 07:52am Link  |  Quote  |  Print  |  Notify Moderator
ALL LP refers have a spiral baffle that hangs inside the burner flue just inside the tube above the flame. The purpose is to distribute the Heat from the flame evenly to Heat the fluid. After 30/40 years that baffle has probably rusted/burned up a part of it and a piece fell down on the burner. Look at this link and you will see a picture of this baffle. Now, usually this part is NOT available
You have to find one i n a throwaway refer or build your own. These are from my OLD notes. Doug
From my notes for the RM763-
WIRE LENGTH IS 25-1/2"
BAFFLE LENGTH IS 5-7/8"
TOTAL LENGTH 31-1/4"
BAFFLE WIDTH IS 3/4"
https://escapees.com/rv-refrigerator-part-2-lp-gas-operation/
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 04/15/23 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I think at that age, it's long past retirement age.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
dougrainer
Carrolton, Texas
Posted: 04/15/23 08:44am Link  |  Quote  |  Print  |  Notify Moderator
You are given a 40 year old car with a bad starter. Car was running great. According to YOU, just take it to the junk yard. The OP has a $1000 refer and for less than $30, it will function just fine. Doug
Posted: 04/15/23 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Well I think you found the problem.
Replace the thermocouple.. Take the old one to a Heating and cooling specialist and see if they have one to replce it
Physically you need the hot end to match
Electrically you need the same connections at the control housing.
Cable length is "At least long enough"
Electrically they are most all identical so if it's a pysical match I'd anticipate good results.
fourthclassC
MA
Posted: 04/19/23 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Doug R. -
You are right. Throw away useful items is a waste....
An old fridge like that may be better then a modern one because it might not need any power to run. (no gas solenoid to hold open with 12v)
Again - thank you for your truthful comments.
Posted: 04/19/23 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I love people that do…and wish more did!
 > gas fridge
