Connor24
Riverhead NY
Whats the best brand for Travel trailer lighhting
2oldman
NM
All you use is lighting?
RLS7201
I believe the best bang for the buck is two 6 volt golf cart batteries from Sam's Club or Costco.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
MFL
Midwest
OP...you need to give more info, as to use? If just for RV park, always shore power, or boondocking sometimes? Lots of good options depending.
I use Interstate brand 12V RV/Marine due to mostly shore power hookup availability.
Jerry
time2roll
Off the shelf?
https://www.us.sokbattery.com/product-pa........ifepo4-battery-bluetooth-built-in-heater
Home built can be an especially good value.
https://www.18650batterystore.com/products/eve-lf280k
https://www.18650batterystore.com/products/jk-bms-4-8s-12v-jk-b2a8s20p
675w Solar pictures back up
Connor24
Riverhead NY
I use it for lights and refrige while boondocking. Refrige running on gas.
pianotuna
Regina, SK, Canada
best all around battery is SiO2. Pocket book "ouch".
First report I've seen on facebook of someone who disconnected their Li battery in the fall at 50% state of charge. Temperature was -5 c (23 f)at the lowest. Now they have two expensive door stops.
Regards, Don
Old Days
Colorado
I am planning to buy 2 Renogy 100 amp hour batteries from Amazon for the trailer they are $189 dollars each.
2oldman
NM
Connor24 wrote: I use it for lights and refrige while boondocking. Refrige running on gas. That's it? A used car battery would handle that.
RLS7201 wrote: I believe the best bang for the buck is two 6 volt golf cart batteries from Sam's Club or Costco.
Richard
This.
