RV.Net Open Roads Forum: Class A Motorhomes: Recommended tools for a newbie
 > Recommended tools for a newbie
cdnroadwarrior
Canada
Posted: 04/16/23 09:44am Link  |  Quote  |  Print  |  Notify Moderator
I am new to the Class A world, in the midst of buying my first one and would appreciate suggestions from the community on what the recommended tools, accessories (extention cords, spare sewage and water hoses etc) and safety items I should buy to be as prepared as possible. Thanks in advance.
RedRollingRoadblock
Oregon
Posted: 04/16/23 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I carry two 25' water hoses and a 15' 50 amp extension cord. I only needed one or the other twice. 15' and 10' sewer hose, used the extension several times.
For tools: a digital volt meter, Wago wire connectors, misc wire. 3/8 and 1/4 drive scoket set. Screwdrivers, including a #2 square, pliers, hacksaw blade w/ holder, locking pliers, couple of flashlights. Duct tape, electrical tape, blue tape, wire ties, Loctite Blue. Spare water filter. Mouse traps. Older 12v battery drill and drill bits.
But wait there's more...But I'd have to inventory.
RLS7201
Posted: 04/16/23 11:37am Link  |  Quote  |  Print  |  Notify Moderator
To add to what RedRollingRoadblock said. I carry a square drive screw set, adapters to drive sockets with my 1/2" battery powered drill motor. Torque wrench & a baster to add ATF to the ZF emergency brake. (mine leaks a little).
OH! and the wife to nag a little..............
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Matt_Colie
Southeast Michigan
Posted: 04/16/23 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Wow,
Red Rolling's list is about as good as you can get - but he should have prefaced the list with "if you are comfortable with" and then noted that the exception is the voltmeter. You want to have that even if you don't know which end to hold... If you need help in that area you may be able to engage a native guide.
The only things I would actually add to his list would be wraps of combination wrenches (SAE and MM) because you can't always get a socket on what needs to be tightened and a largish adjustable wrench just in case...
Other than that, if you are really going to go traveling, try to get all the service documentation for everything that the coach is made of. There have been times that I have helped others that were in minor trouble and he could not find anybody that knew enough to figure out the problem. One of said had a library of documentation, and we were able to diagnose the problem and order parts.
Matt_C
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
enblethen
Moses Lake, WA
Posted: 04/16/23 11:52am Link  |  Quote  |  Print  |  Notify Moderator
An inexpensive multimeter with instructions. Learn how to use it!
Electrical adapters. if rig is 50 amp, get a fifty to thirty adapter.
Bucket and brush to wash windshield. Bucket can be used to put out campfire.
Make a list of appliances with make, model and serial numbers. When does appliances fail? in the dark, raining and cold!
Manuals for appliances.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
enblethen
Moses Lake, WA
Posted: 04/16/23 11:53am Link  |  Quote  |  Print  |  Notify Moderator
OOPS! double post
* This post was edited 04/16/23 12:08pm by enblethen *
oldave
Tx
Posted: 04/16/23 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I do like having lots of tools. I used to cram just about everything I owned into my MOHO, but gradually it occurred to me that 90% of those I never touched.
At 82 I don't know if I want to be working on it anyway. I still take too many and I'll just buy what else I need when needed.
To a great extent, it depends on you and what you buy. Some people are always working on something even if it doesn't need any work, and some won't touch a thing. In time you'll figure it out.
Oh, BTW, a 20 ft set of jumper cables can save you a lot of grief.
ferndaleflyer
everywhere
Posted: 04/16/23 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
All of the above + a gen fuel filter and a motor belt. Add to that a good emergency road service and a large limit credit card. Cash will also work!
cdnroadwarrior
Canada
Posted: 04/16/23 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
You all ROCK. Thank you.... Thank you.... Thank you! I'm hoping to secure a Winnebago 35F or 36Z, awaiting the dealer advising availability so I can get my order in. I invite any further suggestions for an excited newbie.
Flyfisherman128
Broadalbin, NY
Posted: 04/16/23 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
I know I'm going to take a bunch for this but after 20 years of full timing in a class A.. chances are your not going to have what you need.. having to ask the question indicates your experience level ..make sure your roadside service is paid up.. make the call.
