RV.Net Open Roads Forum: Fifth-Wheels: Tire Pressure Monitoring System for FW
 > Tire Pressure Monitoring System for FW
2oldman
NM
Posted: 04/19/23 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
scottandgaye wrote:
I could probably find any number of 12 volt circuits in and around the converter that I could use.
My repeater sits in the refer compartment because it's directly above the wheels and it's a handy place to put it... and the 12v supply is there.
RAS43
Littleton,CO
Posted: 04/19/23 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
scottandgaye wrote:
I could do that. I could probably find any number of 12 volt circuits in and around the converter that I could use. I just don't want any parasitic load on the unit.
Scott
My Pressure Pro system's repeater has an end that plugs in to a 12volt outlet that we have in the bedroom closet. Easy to plug in before a trip and unplug at a campsite. It will pick up the signals from the trailer tires and the boat trailer behind it.
corvettekent
Marysville, WA
Posted: 04/19/23 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
My 2022 Chevrolet had a $50 TPMS option. I had the same problem as you with the hole in the wheel being to big. New wheels cost ne $600.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
