RV.Net Open Roads Forum: Fifth-Wheels: Hitch questions
 > Hitch questions
MNRon
Tennessee
Posted: 04/19/23 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Troy - Solitude was on our short list when we finally decided on the 35ft Vilano, largely because of the woodwork. The 35ft Solitude is the same floor plan as ours, and even larger tanks, you’ll love it. We toured GD and were impressed, and I know several GD owners. Enjoy! (And get a Superglide [emoticon]
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
laknox
Arizona
Posted: 04/20/23 10:11am Link  |  Quote  |  Print  |  Notify Moderator
CarnationSailor wrote:
"ALL will hit when backing up..."
I have not heard that before. Please explain why that is true.
Thanks
Because as you back up, you can go well past 90°, thus hitting the truck. Mostly it would be in a back and fill situation, but not always.
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
MFL
Midwest
Posted: 04/20/23 10:43am Link  |  Quote  |  Print  |  Notify Moderator
troy t wrote:
So we just got our new truck, a Ford F350 with the 6'9" box and 5th wheel hitch prep package. Our reason for upgrading trucks was to upgrade campers to a 5th wheel.
I've done some google searching and see a plethora of answers but my question on hitches is do I need to go to a sliding hitch or will a fixed hitch be fine? Still looking for the perfect camper but I'm searching for hitches so when we're ready to buy a camper we can go get it. It'll be a newer camper with the rounded corners if that helps.
Thanks!
Slider/no slider, always a debate, when using a standard size 6.9' Ford bed.
Fact is, FW manufacturers have been designing rounded/recessed fronts, with extended pins, for many years now. They are designed to work with most 6.5' bed trucks, which are far more popular than a long bed.
As I suggested, in a different thread, the B&W 3300 for Ford puck system is a great choice for your truck. It drops right in the pucks, your wife, or GF could install it, or do it together, if they wanted.
This hitch is adjustable up/down, ahead/back. At 40"s behind cab, with modern FW design front, you would have to be lacking common sense to hit the cab.
You are used to backing trailers, TT and sled trailers IIRC. You cannot back either of these, without hitting at some point. Common sense applies the same when backing a FW.
No one is backing any trailer at 90 degrees, that is just twisting the axles sideways, not backing. Just a slight pull ahead, straighten a little, just like a bumper pull, and back again during a tight back-in
The B&W hitches are solid, more user friendly than most. You won't be disappointed!!
Jerry
troy t
home
Posted: 04/20/23 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you are correct. I have lots of experience pulling trailers and some were pretty big. Also grew up on a farm so I've been backing up equipment for 45 yrs. No worries there. Although I did get the corner of my 25' enclosed sled trailer into the corner of my truck once when we hit black ice at 60 and ended up looking the wrong direction on the freeway once.
As far as hitches, I found a lightly used B&W 3300 companion with the Ford pucks and am picking it up saturday. I appreciate all the good advice from everybody.
* This post was edited 04/21/23 06:31pm by an administrator/moderator *
ford truck guy
Pennsylvania
Posted: 04/21/23 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Boy, I LOVE good finds like that ! ! ! ![emoticon]
I hope your as happy with it as myself , Jerry, The Fan Boy Prez, and all other B&W user all are ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
 > Hitch questions
