RV.Net Open Roads Forum: General RVing Issues: Jeep exploded ...
 > Jeep exploded ...
monkey44
Cape Cod, MA and Central Fla
Posted: 04/25/23 02:36pm Link  |  Print  |  Notify Moderator
To follow up on the above comments -- yes, this community does have gas water heaters and gas home heating units in the garage. The Jeep was not an EV, am sure of that. No official word yet, but gas leak appears the cause. Not sure yet if the gas leak was natural gas, or Jeep fuel. Apparently, Jeep has a recall on the Jeep fuel lines leaking. That's all I know ...
Well, that's not ALL I know, but ... [emoticon]
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
JRscooby
Indepmo
Posted: 04/25/23 04:10pm Link  |  Print  |  Notify Moderator
Grit dog wrote:
I’m not aware of any state, maybe MO based on scoobys post, that doesn’t allow appliances in the garage like furnace and water heater.
I know houses in the area my area will not pass inspection if both sides of walls surrounding the utility room (furnace & water heater) are not finished. And IIRC, had to use thicker sheet-rock than normal inside walls.
monkey44
Posted: 04/25/23 07:36pm Link  |  Print  |  Notify Moderator
We have block walls between garage and house ... but the fire went UP and thru the adjoining attic. So, the fire wall did not work as it should. No firewall exists between garage attic and house attic.
Might not be able to build homes that way anymore ... not sure of the newest codes here.
bob_nestor
murphy
Posted: 04/26/23 02:09pm Link  |  Print  |  Notify Moderator
The building codes in many areas require outside air and ventilation for any gas fired appliance, thus they get installed in the attic or garage. You'd have to break the air infiltration barriers to install them inside, and that works against trying to make the living areas as energy efficient as possible.
Posted: 04/26/23 02:17pm Link  |  Print  |  Notify Moderator
Ok?
dedmiston
Coast to Coast
Administrator
Posted: 04/26/23 06:37pm Link  |  Print  |  Notify Moderator
I think we've gnawed all the meat off this bone.
Closed.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
 > Jeep exploded ...
