No pics needed. As identified earlier, a big part of the issue is, you’re running those little tires to death IMO. Combined with either some bad luck, bad roads or cheap tires.
You have a repeatable problem it seems so I’d expect to have to change something to achieve different results.
B-n-B
Colorado
GTO66 wrote: As far as posting photos may be easy for some. Just like rebuild a Pontiac engine is easy for me...
http://photoposting.is-great.net/?i=3
2019 Chevy 3500HD LTZ DRW
2021 Lance 975
jjj
Lancaster,Ca.U.S.A.
My 2002 dually came stock with 235/85/16 which care 3042 lb versus
the 215/85/16 which is a little over 2600 lb. I
am always told when looking for tires I have the wrong
size on my truck but my door sticker says different.
235'may give you more capacity and will still fit. Just a thought.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
GTO66
I'll give serious thought to increasing the size to a 235. I did that once but was concerned it lessen the space between the duals,and I believe the small space now is causing excessive heat. Also wonder about clearance issues on the front..... Thanks
Geo*Boy
Unknown
Put Michelin or Bridgestone/Firestone tires on your truck. My 2015 GMC 3500 dually has a AF 990 that weighs 4500+ lbs and my original Michelins will go 50k miles easily.
GTO66 wrote: I'll give serious thought to increasing the size to a 235. I did that once but was concerned it lessen the space between the duals,and I believe the small space now is causing excessive heat. Also wonder about clearance issues on the front..... Thanks
You can use dodge rims. Look at the offsets. There’s dually wheels that fit 235/245 width tires just fine If the old GM rims are too narrow. Or not enough offset.
edited 04/27/23 09:59am by Grit dog *
