RV.Net Open Roads Forum: Truck Campers: Truck tires
 > Truck tires
Posted: 04/26/23 10:27am Link  |  Quote  |  Print  |  Notify Moderator
No pics needed. As identified earlier, a big part of the issue is, you’re running those little tires to death IMO. Combined with either some bad luck, bad roads or cheap tires.
You have a repeatable problem it seems so I’d expect to have to change something to achieve different results.
B-n-B
Colorado
Posted: 04/26/23 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
GTO66 wrote:
As far as posting photos may be easy for some. Just like rebuild a Pontiac engine is easy for me...
http://photoposting.is-great.net/?i=3
2019 Chevy 3500HD LTZ DRW
2021 Lance 975
jjj
Lancaster,Ca.U.S.A.
Posted: 04/26/23 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
My 2002 dually came stock with 235/85/16 which care 3042 lb versus
the 215/85/16 which is a little over 2600 lb. I
am always told when looking for tires I have the wrong
size on my truck but my door sticker says different.
235'may give you more capacity and will still fit. Just a thought.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
GTO66
Posted: 04/27/23 07:20am Link  |  Quote  |  Print  |  Notify Moderator
I'll give serious thought to increasing the size to a 235. I did that once but was concerned it lessen the space between the duals,and I believe the small space now is causing excessive heat. Also wonder about clearance issues on the front..... Thanks
Geo*Boy
Unknown
Posted: 04/27/23 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Put Michelin or Bridgestone/Firestone tires on your truck. My 2015 GMC 3500 dually has a AF 990 that weighs 4500+ lbs and my original Michelins will go 50k miles easily.
Posted: 04/27/23 09:51am Link  |  Quote  |  Print  |  Notify Moderator
You can use dodge rims. Look at the offsets. There’s dually wheels that fit 235/245 width tires just fine If the old GM rims are too narrow. Or not enough offset.
* This post was edited 04/27/23 09:59am by Grit dog *
 > Truck tires
