RV.Net Open Roads Forum: Tech Issues: Norcold Refrigerator Carbon Buildup on Flame Probe
 > Norcold Refrigerator Carbon Buildup on Flame Probe
KenS999
West Dundee, IL
Posted: 04/20/23 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Hello I have a Norcold N306RM8 in my 2017 Forest River Cherokee Wolf Pup. Seem to be plagued by carbon boogers building up on the flame probe running on LP. What causes them? Replaced the burner tube/orifice about a year ago. Recently replaced New Flame probe as it was burned up. Today replaced burner tube / orifice again with a new one to see if that corrects the issue. It seems when there is carbon build up on flame probe the refrigerator does not cool as effectively while running on LP.
Thank you,
Ken
eHoefler
ozark mountains
Posted: 04/21/23 04:08am Link  |  Quote  |  Print  |  Notify Moderator
You are running rich, not enough oxygen. Check the full length of the burner tube and chimney. Make sure it is clear of wasp nest and spider nest. Make sure your flame is not yellow, lastly adjust your flame fuel screw if everything else is clear.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
C Schomer
Pueblo West, Co.
Posted: 04/22/23 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Id checked the gas pressure too. If the pressure is low, the btu input will also be low but it will also draw in less primary air. A dust free, clean orifice is also important, but that doesn’t sound like it would be a problem in your case. Be sure the burner is super clean, so nothing restricts the primary air intake.
If it still soots after all that cleaning Id figure out a way to get more primary air… by hook or by crook, there are ways. Craig
KenS999
West Dundee, IL
Posted: 04/23/23 12:35am Link  |  Quote  |  Print  |  Notify Moderator
"Make sure your flame is not yellow, lastly adjust your flame fuel screw if everything else is clear."
Thanks. Flame is blue. Where is this fuel screw that you mentioned located at? Burner tube/orifice is a single piece, and brand new. Ken
ScottG
Bothell Wa.
Posted: 04/23/23 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Good idea. I had suspicions about my pressure so I built a manometer and found that my reg not only wasn't regulating, it would drop to 10" with more than one appliance running - the the reg was only 4 y/o!
A new American made regulator has everything running perfectly.
dougrainer
Carrolton, Texas
Posted: 04/23/23 09:26am Link  |  Quote  |  Print  |  Notify Moderator
There is no fuel adjustment screw. I would remove the orifice and make sure it is not partially blocked. I would blow compressed air UP the burner tube to clean it out. If the refer is in a slide room you can remove the burner baffle from the upper vent door. Otherwise you will have to pull the refer to verify Burner baffle and no debris. An EASY check of a regulator without a Manometer is to light the range burners(all 3 or 4). Then run the water heater on LP and the Furnace. IF the range burner flames rapidly pulsate up and down or diminish, your regulator is BAD. Replace it. Doug
KenS999
West Dundee, IL
Posted: 04/23/23 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
KenS999
West Dundee, IL
Posted: 04/23/23 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Question, can I blow compressed air up the exhaust flue to clean it? My flue does not go up to the roof but exhausts out a upper vent. It's only about two and a half feet long but not sure how to disassemble it. Would rather not if I don't have to. Thanks.
Posted: 04/23/23 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Generally on a propane appliance it is correct there is no "Fuel Adjustment Screw" Like there is on a gasoline carburetor.
What there is an air adjustment slider This is OFTEN (But not always) a window in the large tube past the oriface with a slider over it.. If you are running rich you slightly loosen the screw open the window a bit more (Then tighten the screw) if running lean you Same procedure but close it a bit.. Slide it open/closed till you get the best flame.. If you do not know how seek professional help.
I grew up with propane so have done several adjustments over the decades.
dougrainer
Carrolton, Texas
Posted: 04/23/23 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
This is great. Remove the upper door and remove the baffle. It is on a long metal wire and just pulls up. Doug
https://escapees.com/rv-refrigerator-part-2-lp-gas-operation/
