RV.Net Open Roads Forum: Fifth-Wheels: Replacement axle question.
 > Replacement axle question.
JRscooby
Indepmo
Posted: 04/23/23 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
wing_zealot wrote:
Just who is the "they" you are referring to? There are 3 people involved here.
1) The axle manufacturer welded the spring perches to the axle.
2) The trailer frame manufacturer welded the spring shackles to the trailer's frame.
3) All the installer of the new axle did was remove a few bolts, swap out the axle, and re-install the bolts. Any teenager with the right wrenches could take the old bolts out and put them back in (even torque them correctly).
So who is the incompetent "they" guy you are inferring to?
Well, you are right, many people could be responsible. Is the OP that laid down the money 1? If I make a a frame, I make sure the frame is square, hangers are same distance from ball. If I build a axle, I make sure the spring perches are same distance from center. (Yes, I have done both). And if I install any part, I make sure the part is right. If I bought the parts for job, and the axle rides off center, I would be checking as to why. Is the axle made wrong? Get ahold of supplier for replacement. Is it the frame that is the issue? (OP stated bent axle. Is anybody sure the force that bent axle did not do more harm?) Point that out to owner, just to make sure it is not my donkey that gets the bite.
fj12ryder wrote:
Actually I can't see any harm with a 1/2" short on one side, as long as the axle is parallel to the other axle and straight and true. The tires aren't going to care whether they're directly in line with the one in front of it. No reason to think there would be any tire wear at all. It's way different from front end of a car/truck. Different story if the axles is incorrectly aligned, or bent.
You are right, no issue if the axles are parallel. What I see as the issue is if installed offset, how can we be sure they are parallel?
Did anybody take note of my first take?
First, it is normal for axles to walk side to each as you turn. I would think if you stopped to check while going in straight line both axles should be centered.
shadows4
Kansas City, Mo
Posted: 04/23/23 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Original Poster here. I got back under the trailer and took more measurements. The axle is aligned correctly and centered as it should be. I feel like an idiot but when I sighted down the trailer I was lining it up with the concrete pad it was on. I was showing my camping buddy how off it was. He said, "no it's not, the trailer isn't straight on the pad!!!" Dang, he was right!!! That's when I remeasured the axle.
Thanks for all the replies sorry for being a dunce. I don't drink but maybe I should start!!! LOL
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 223,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
MFL
Midwest
Posted: 04/23/23 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
No apology needed on these forums. Happy your buddy was able to clear it up!!
No reason to start drinking now, especially with recent legalization of weed! [emoticon]
Jerry
fj12ryder
Platte City, MO
Posted: 04/23/23 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to hear that the issue was...a non-issue. [emoticon]
Howard and Peggy
"Don't Panic"
ford truck guy
Pennsylvania
Posted: 04/24/23 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
A side of Jerry I didn't know ! ! ! ! [emoticon]
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Midwest
Posted: 04/24/23 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
A little kidding amongst friends, adds fun to the forum!! However, if you don't mind, I enjoy doing it, rather than being the recipient![emoticon]
Bwa hahaha
Jerry's a pretty straight guy, as I'm sure John (OP)is as well. Hope he took no offense to my attempt of humor.
