RV.Net Open Roads Forum: Toy Haulers: 2007 Desert Fox 24AS Ramp Hinge
Search only in Toy Haulers
 > 2007 Desert Fox 24AS Ramp Hinge
wolverine68
Alberta, Canada
Posted: 04/24/23 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a broken hinge on the ramp door of my 2007 Desert Fox 24AS which I bought new in 2009. I've contacted Northwood and they were of no help identifying the parts I need. I've contacted Lippert and they say that they need information from the label on the frame of my ramp door. I've checked mine and a friend's 24AS and neither have a label. I would like to replace the entire assembly but I'm not sure which springsĀ ??????? IĀ need. I have 4 springs with 15 coils each. Has anyone dealt with this before?
* This post was edited 04/24/23 07:12pm by wolverine68 *
04 Chev LLY Duramax
07 Desert Fox 24AS Toyhauler
Bikes and quads to fill the toyhauler
wolverine68
Alberta, Canada
Posted: 04/24/23 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Unsuccessfully trying to upload pictures lol.
MFL
Midwest
Posted: 04/24/23 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
google rv.net photo posting
wolverine68
Alberta, Canada
Posted: 04/24/23 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!!
Y-Guy
Tri-Cities, WA
Posted: 04/25/23 07:54am Link  |  Quote  |  Print  |  Notify Moderator
I camped with a couple friends that had DF Toy Haulers the really big 5er and one about the size of your rig. I'm disappointed that Northwood wouldn't be of more help.
If you were in Idaho, as your plate suggested I'd say contact Drakes RV Repair in Pendleton Oregon (541-278-8170), but from Alberta that probably isn't worth it. At the time I used them they had repair teams that had worked for all the manufacturers in the area including Northwood, Fleetwood and Keystone, they might be worth a call for advice/direction.
Here is an older thread that might be helpful, talks about a spring manufacturer called Holmes Springs now called IDC Spring
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
wolverine68
Alberta, Canada
Posted: 04/27/23 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Yguy. That gentleman seemed pretty knowledgeable. Ultimately he did not know where to source the same springs, but he did provide an educated guess as to which springs to use.
Y-Guy
Tri-Cities, WA
Posted: 04/27/23 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
@wolverine68 sorry wasn't of more help, but hopefully gives you some direction. Best of luck!
