RV.Net Open Roads Forum: General RVing Issues: 38 gallon honey wagon?
 > 38 gallon honey wagon?
rk911
DuPage County
Posted: 04/24/23 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
look at the total shipped price. Amazon indicates free shipping. the other will add $50 frieght charge.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
time2roll
Posted: 04/24/23 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Conserve water and skip the tote. Is there a shower house and restroom? Use it when you can.
675w Solar pictures back up
corvettekent
Marysville, WA
Posted: 04/24/23 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
I think that you need to look at this another way. You did not say how many people will be staying in your RV for one week, so I will use my 5th wheel as an example. I have a 45 gallon black tank and it takes two of us 20 days to fill it. That's 1.125 gallons per person per day. So, after one week of camping, we would only have 15.75 gallons in our black tank.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 04/24/23 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
After a w0eekend of regular usage, our tanks get about 1/4-1/2 full. Our largest tank is 38 gallons. So, I want to be able to dump it as needed and not have to not use the facilities we have.
wildtoad
Blythewood, SC
Posted: 04/25/23 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Having a tote allows us to use water more freely, and avoid the “you’re using too much water” conversations.
Now back to tote size. Yes you can pull the tote with your truck once you get it to the truck. I’ve found even my smaller 25 gallon tote a bear to pull on uneven ground that I find at many CG’s especially state parks. If I need to I’ll make a couple of trips, but most of our stays using it once will provide enough room in the black tank to finish the stay. Gray may need multiple if I chose not to use the CG facilities for shower, or the lake.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
way2roll
Wilmington NC
Posted: 04/25/23 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Following this conversation as we stay in a lot of state parks. Question - where do you put the tote when not using it? In a bin?
* This post was edited 04/25/23 09:46am by way2roll *
2023 FR Sunseeker 2400B MBS
Posted: 04/25/23 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Well that may be an option albeit wholly opposite of the OPs apparent intention to use his camper for those “duties.”
swimmer, another option if you’re not planning on regular use, see if there’s a local turd burglar that services the campground. Might be cheaper and hitting the easy button to just have it pumped out mid week.
ScottG
Bothell Wa.
Posted: 04/25/23 10:13am Link  |  Quote  |  Print  |  Notify Moderator
The three of us can go a week without dumping the Black (42 gal tank). We do use the CG facilities occasionally (#2..) but mostly use our own. For the grey to last a week (incl showers), I have a 5 gallon jug that I dump the grey in daily and then carry it to the restrooms for disposal in a toilet. I also use a wash basin in the sink and dump that separately. This gets rid of the bulk of grey and allows us to easily last a week.
Lantley
Ellicott City, Maryland
Posted: 04/25/23 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
With my 40 gallon grey tank I can go 3-4 days before I need to dump my tank without any water conservation. My galley drains into a separate grey tank so I actually have 80 gallon grey capacity.
The 42 gallon Barker tote allows me to fully dump my 40 gallon grey every 3-4 days as needed.
I have never stayed anywhere long enough to fill my 40 gallon black tank
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
wildtoad
Blythewood, SC
Posted: 04/25/23 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
In my case when not using it at home, it goes in a storage building, and only comes out when we go to a site with no sewer. I place it in the only bin I have big enough.
While at a cg, I pull it from a storage bin before deploying the slide above, and store it under the RV close to the dump valve.
I have seen a lot of rv’s going down the road with the tote sitting on a ladder rack and bungeed to the ladder.
* This post was edited 04/25/23 03:29pm by wildtoad *
