Diamond c
West ky
On our way home from our last trip last fall the door to the compartment that holds the propane tank on the driver’s side of our fifth wheel came open while going down the road. Instead of fixing it over the winter I forgot about it. Last weekend while setting up at camp I noticed that the top latch on that same door was about half turned. While talking to my brother-in-law yesterday I mentioned it to him and that I was thinking of replacing the ( twist) latch with a lock. He suggested to take it apart and move the blade 90 degrees so that gravity and road vibrations would pull it closed instead of open. To which I’ve done this evening. It’ll be 8-10 weeks before we can go out again because of work obligations, to test it out and see if it works. But worth a try for the price. Does anybody else have any experiences, recommendations, or tips?
enblethen
Moses Lake, WA
Litle off topic: propane compartments are not supposed to be locked.
I turned some of my locks, so the key or handle face the direction of the interior locking arm. That way you can see they are locked or secured.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Bobbo
Wherever I park
I agree with enblethen. A propane compartment is not supposed to be lockable. That way, in case of some emergency, emergency personnel can turn off the propane tanks.
Bobbo and Lin
MrWizard
Traveling
I think he just meant latched,, he asked about the lock and was correctly informed .. do not lock
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
Bobbo
Wherever I park
MrWizard wrote: I think he just meant latched,, he asked about the lock and was correctly informed .. do not lock
I hope you are right. This is what we were responding to though.
Diamon c wrote: ....replacing the ( twist) latch with a lock.
jkwilson
Indiana
I believe that’s the way mine are from the factory, but I’ll check when I’m outside
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
bpounds
Sophmore Brain...
There are a lot of door and frame designs out there, so I don't know if this will work for you, but ...
I simply bent a slight tweak in the door stop flange of the door frame, so the latch has a bit of a cam-over point. It won't ever vibrate over that hump and become unlatched. Easy and cost $0.00.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
12thgenusa
Loveland, Colorado
When I first got my trailer, many of the latches were installed as you describe, and one door came open on a trip. I then re-clocked all the latches so that gravity and vibrations would not work against the latch staying locked. There have been no problems since.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
dave54
Northeast CA.
Bobbo wrote: I agree with enblethen. A propane compartment is not supposed to be lockable. That way, in case of some emergency, emergency personnel can turn off the propane tanks.
Doesn't take much effort to open a locked RV bin.
So many campsites, so little time...
Bobbo
Wherever I park
dave54 wrote: Bobbo wrote: I agree with enblethen. A propane compartment is not supposed to be lockable. That way, in case of some emergency, emergency personnel can turn off the propane tanks.
No, as long as you have the key. (Or, are willing to break it.) In the event of an emergency of any type, the emergency responders won't have the key. This is only for the propane bin, where emergency responders may need to turn off the propane VERY quickly (without breaking it).
