Oreonut
DE
So I got my fridge question answered and now on to the hot water heater. Our trailer was advertised with a gas only hot water heater. Upon investigation it has a breaker in the back and a plug under the sink labeled for the hot water heater and the heater model is also gas/electric. The switch inside the camper only controls the gas.
Any reason why they would set it up as just gas and not electric?? Would there be any reason we couldn't still just put a switch under the sink for that plug and use it as electric when plugged in?
Just seems so weird they didn't put in an electric switch next to the gas one like the old days.
2023 Forest River RV Wildwood 31KQBTS
Thanks!
Kelly
2023 Chevy Silverado 2500 HD
2023 Forest River - Wildwood 31KQBTS
Blue Ox
Old Set up:
2006 Chevy Silverado 2500 HD
2007 Sunset Creek 298 BH
Hensley arrow/Prodigy
CarnationSailor
Cathedral City, CA
In "the old days", there was a gas switch inside and an electric switch outside on the heater itself. Maybe look for a rocker-type switch on the outside of your water heater?
FYI: Forest River's spec's for this trailer says the water heater is "Gas/Electric DSI".
edited 04/26/23 04:24pm by CarnationSailor *
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
katysdad
Virginia
Sounds like a suburban water heater. A switch in lower left corner of heater behind exterior cover and a breaker in the panel box to control 120 volt side. Atwood water heaters had the electric switch on the panel with the gas switch.
Dodge Ram 3500 DRW Diesel
Boon Docker
Oreonut wrote: So I got my fridge question answered and now on to the hot water heater. Our trailer was advertised with a gas only hot water heater. Upon investigation it has a breaker in the back and a plug under the sink labeled for the hot water heater and the heater model is also gas/electric. The switch inside the camper only controls the gas.
Thanks!
No reason you could not do that if done properly.
bob213
Fresno, CA
Look in outside compartment. As stated above..lower left corner:
johned
carbondale, colorado
I looked at your refrigerator post and can't tell if you bought this trailer new or used from a dealer or a private party. If it's a dealer they should be able to answer this question. I know in my previous arctic fox in order to activate the 120 volt feature I flipped the switch that you show in your photo AND then activated a switch on the control panel inside the trailer. You may have the same setup. However, you may have a heater that's 120 capable that was never hooked up. This RV business can get pretty goofy.
PhilipB
MO
Our current 5er has the gas switch inside and the electric on the water heater, as pictured in the previous post.
Our previous 5er was the same, except it did have an electric switch inside. However, the outside electric switch was the master so it had to be on in order for the inside one to work. I liked this set up.
2015 Ram 2500
2013 Raptor 310TS
Boon Docker
Thanks!
No reason why you can not do that.
Use a switch such as this one, so you can tell whether the water heater is on or off.
pbeverly
South Carolina
My water heater has a switch in the breaker box, switch on the heater itself and the gas switch on a control panel. I always turn the breaker switch and outside switch on after I know the tank is full. The gas switch is turned on during showers and washing dishes for faster recovery.
Ridgeway, SC
StirCrazy
Kamloops, BC, Canada
Thanks!
the panels and such are generic when they are built, if there is nothing plugged into the outlet under the sink and nothing hooked up to the braker (or the breaker could be wired to the plug) then chances are your unit didn't come with dual as it is usually an optional upgrade. They are prewired though to make it easy to upgrade it when ordered that way.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
