RV.Net Open Roads Forum: Tech Issues: Trailer hitch height adjustment and chain question
 > Trailer hitch height adjustment and chain question
Page of 5
dougrainer
Carrolton, Texas
Posted: 04/28/23 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
AS to too long chains. JUST TWIST THE CHAIN UNTIL YOU GET THE CORRECT LENGTH. Doug
Reisender
NA
Posted: 04/28/23 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
eHoefler wrote:
You will need to get an equalizing hitch to tow that correctly and safely. You may also be beyond the tow capacity of your car.
Howdy. Many Audis are not rated for weight distribution hitches and Audi recommends against them for those models. Common for mid size or smaller SUV’s. Not sure about the OP’s Audi.
bikendan
Goodyear, Arizona
Posted: 04/28/23 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
nickthehunter wrote:
It’s a single axle trailer; I’d be more concerned about the payload rating and tow rating of that car vs. the tongue weight and GVWR of that trailer. Clicky
Totally Agree! I'm betting that the loaded tongue weight is exceeding the car's max hitch weight.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Reisender
NA
Posted: 04/28/23 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if it’s a Q7 or not. I helped a fellow setting up his Q7 for a T@B 400. The tow info table covered a few configurations and went from 4400 to 7700 pounds towing capacity and 440 to 770 pound hitch weight. He had no problem with the T@B but don’t know what this trailer is for weight. Point is it may be fine depending on the cars options. A weight distribution hitch was specifically not recommended so probably not an option for the OP.
neu
Toronto
Posted: 04/28/23 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Audi Q5 2018 and according to the specifications, it seems to be capable of handling a 440-lb tongue weight.
Can the 2018 Audi Q5 Tow?
My trailer is called a Viking Saga 16sfb 2017, and I cannot find the specific characteristics for my year of production. However, for the new models of 2022, the Hitch Weight appears to be 363 lbs. If I understand correctly, this falls within the specification range.
Specs for 2022 Coachmen - Viking Saga Floorplan: 16SFB
The towing capacity of my car is 4,400-lb, which should be enough to cover the GWVR of 3,675-lb that my trailer has.
Please correct me if I am wrong about anything. It's all new area for me
neu
Toronto
Posted: 04/28/23 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
This is a Q5, but I understood the essence of your message, thank you.
neu
Toronto
Posted: 04/28/23 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds quite logical. I will try that if the problem persists after installing a different hitch. Thank you!
Reisender
NA
Posted: 04/28/23 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Neu. Probably best to weigh the hitch after it’s loaded as well. Some trailers get quite a bit heavier on the hitch after battery and propane are added. Try to pack accordingly to keep the hitch weight under control. Front storage compartments are nice but if you are struggling with hitch weight maybe pack the light stuff up front.
Happy camping. [emoticon].
neu
Toronto
Posted: 04/28/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! You too!
GaryUT
Northern UT
Posted: 04/28/23 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Do not twist the chains. Replace the hooks with clevis hooks, they will let you adjust the length of the chain.
https://www.amazon.com/CURT-81920-Safety-Latch-Clevis/dp/B000BMXICE
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
Page of 5
