RV.Net Open Roads Forum: Tech Issues: Securing a Camper Trailer Stabilizing Jack
 > Securing a Camper Trailer Stabilizing Jack
neu
Toronto
Posted: 04/27/23 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hi there!
I had an issue with my camper trailer as one of the stabilizing jacks was missing when I bought it. I ordered one of the most popular jacks on Amazon, and it came with "self-tapping screws" for installation, which we used to attach it to the existing holes. My other three jacks are attached to the frame using screws.
Can you help alleviate my doubts: would using four of these self-tapping screws be sufficient for secure attachment? It feels like it's firmly attached with them.
If the manufacturer supplies jacks with these self-tapping screws, then it must be intended for this purpose.
Please share your experiences guys
BB_TX
McKinney, Texas
Posted: 04/27/23 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
The bolts don’t really do anything except keep the stabilizer from falling off. All force is between the trailer frame and the stabilizer frame. With the wheels properly chocked there should be no lateral movement.
neu
Toronto
Posted: 04/27/23 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
My question is solely about my concern, or is there a risk of it falling apart while driving. So, from your perspective, is there nothing for me to worry about?
98coachman
North Idaho
Posted: 04/27/23 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
You will be fine. Go camping and enjoy !!
neu
Toronto
Posted: 04/27/23 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!!!
StirCrazy
Kamloops, BC, Canada
Posted: 04/28/23 07:13am Link  |  Quote  |  Print  |  Notify Moderator
There is a reason they are welded on from the factory. If you're going to keep with the bolts, get actual bolts and lock washers and nylock nuts and put them on. those screws will vibrate loose as you drive.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
fj12ryder
Platte City, MO
Posted: 04/28/23 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Self-tapping will probably be okay, but if you have room to get to the screws, use regular bolts and lock washers. And provided the self-tapping screws are long enough, you could use a lock washer on them, or even some LockTite.
FWIW, they're probably welded from the factory because it quicker and cheaper, not necessarily better.
* This post was edited 04/28/23 11:31am by fj12ryder *
Howard and Peggy
"Don't Panic"
Tyler0215
Iowa
Posted: 04/28/23 07:40am Link  |  Quote  |  Print  |  Notify Moderator
If you are worried about the screws, get some bolts and lock washers.
BB_TX
McKinney, Texas
Posted: 04/28/23 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Not stabilizers as such, but I added JT Strongarm stabilizer struts to my front jacks and rear stabilizers on my 5er using self tapping bolts thru the frame. After 12 years they never loosened.
opnspaces
San Diego Ca
Posted: 04/28/23 08:53am Link  |  Quote  |  Print  |  Notify Moderator
My 2005 trailer was manufactured with self tapping screws holding the stabilizer jacks to the frame. Thirteen years later the stabilizers are still there under the trailer.
As has been said the screws are just to hold the jack to the frame during travel. When in use the majority of the holding force is the jack pushing up on the frame from the ground.
But if it is a concern you could go to Home Depot and get a few appropriately sized bolts and nuts and replace the screws. If access is difficult you don't even need to replace all the screws. Just replace the one or two that you have easy access to.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
