RV.Net Open Roads Forum: 2022 Salem destination rv has no 12v batteries
 > 2022 Salem destination rv has no 12v batteries
BigDog1333
Durand Michigan
Posted: 04/30/23 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't seen posts about destination RVs.
When power goes out a/c thermostats don't reset. Therefore I have to reset manually.
How do I add 12 volt auxiliary to my power supply source?
I guess I didn't explain completely. This destination rv has no batteries installed. Just a converter from 120v.
Just like all RVs, lights,.thermostats and fans run on 23v.
Are all destination RVs like this?
* This post was edited 04/30/23 01:21pm by BigDog1333 *
SAR Tracker
Central Oregon
Posted: 04/30/23 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I guess the first question would be: What items on the RV are 12v powered? Thermostats in a stick built house are run off a transformer, so they're not really 12v. Lights? Fridge? Water heater? If they are not 12v, then you'll have to have an INVERTER to change the battery power to 110v. And you'll have to have a CONVERTER to charge the battery(ies).
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
joebedford
Home for the summer.
Posted: 04/30/23 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
My RVs batteries are in parallel with the 12V converter.
BigDog1333
Durand Michigan
Posted: 04/30/23 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Please read my edited post.
This rv has no batteries just a converter.
Meant 12v not 23v. Typo
12th Man Fan
Flower Mound , Texas
Posted: 04/30/23 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you have an inverter and not a converter? sorry I read your post wrong. just ignore this post.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Posted: 04/30/23 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
This like the 2nd time I've seen "Destination RV"
IS that like a park model. NO fresh tank. No waste tank Designed to be put on a site and left there? If so then it's designed to always be plugged in and from a "House" standpoint needs not have a battery.
Now from a Towing standpoint... Depending on the weight it may not need aux brakes (Trailer brakes) or it might have a surge brake system that also does not need electrical power... IF it has electric brakes.. then it needs an emergency brake battery.. but only if it has electric brakes.
time2roll
Posted: 04/30/23 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Need to add a battery. As mentioned above... in parallel with the 12v converter is best.
Trouble is where to put the battery. A low cost flooded battery needs venting and there might be no compartment. I recommend a lithium battery to avoid the venting issue.
https://www.us.sokbattery.com/product-page/sok-12v100ah-lifepo4-battery
https://www.renogy.com/12v-100ah-smart-lithium-iron-phosphate-battery/
675w Solar pictures back up
BigDog1333
Durand Michigan
Posted: 04/30/23 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Problem is how connect the batteries in parallel to existing 12v system. I'll see if I can find a schematic for my rv.
pianotuna
Regina, SK, Canada
Posted: 04/30/23 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
BigDog 133,
If the existing converter is not intended as a battery charger it may need to be upgraded or replaced.
Look at the system as if it were an uninterruptible power supply. You want the thermostat to work when the 120 volt power blips or baffs out?
Regards, Don
time2roll
Posted: 04/30/23 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the covers around the converter and the stack of 12v fuses and get some pictures and post them up.
http://photoposting.is-great.net/?i=3
