RV.Net Open Roads Forum: Tech Issues: 12v rv freezer difficult to open,,,suction
 > 12v rv freezer difficult to open,,,suction
dougrainer
Carrolton, Texas
Posted: 05/03/23 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about a FREEZER ONLY? Or the freezer portion of the refer? Model number of the Dometic will help. RV refers do NOT have any equalization valve. Until you answer my question, I cannot give you any more info. Doug
Posted: 05/03/23 10:05am Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
Just tape a 1" piece of small diameter metal tubing to the gasket to break the seal and allow pressure to equalize. That small gap will barely affect the efficiency of the unit.
This too. Like a snip of spray tube from an aerosol can.
Could even punch it thru the gasket if there’s a spot where it’s a straight shot.
Drilling a hole thru the unit in some random place is not preferable
Posted: 05/03/23 10:06am Link  |  Quote  |  Print  |  Notify Moderator
midnightsadie wrote:
maybe try a little silicone spray .
Great idea if the OP had not already confirmed that the issue is NOT freezing in place but rather vacuum.
BB_TX
McKinney, Texas
Posted: 05/03/23 10:08am Link  |  Quote  |  Print  |  Notify Moderator
You might could just pierce the gasket with a large pin or sharpened paper clip to add a small relief vent hole.
Our home upright freezer actually has a pump that starts up and pulls a vacuum for a few seconds every time you close the door. To seal the gasket I suppose. Can’t even open the door for another 20 seconds or so. But never heard of such on an RV freezer.
time2roll
Posted: 05/03/23 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yes a pin to the gasket should be fine.
675w Solar pictures back up
JimK-NY
NY
Posted: 05/03/23 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt it. Remember the gasket is greatly compressed which would close up that pin hole.
ktmrfs
Portland, Oregon
Posted: 05/03/23 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
means you have a good seal on the lid. Our ice coolers have this problem on occasion. Basic physics. Cool the air, density goes up pulls a slight vacuum. Doesn't need to be much before it takes some effort to open the lid.
And our portable 12V compressor cooler/freezer for camping does the same thing.
2011 Keystone Outback 295RE
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 05/03/23 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
It is the freezer portion of the refer. The model# is RM3863.
It's not that big of a deal to use the 90 degree screwdriver, just hoping there might be a permanent solution to release the vacuum pressure.
Just not sure if drilling a small hole in the door jam would work although it sounds feasible.
The gasket does compress and seal properly.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
time2roll
Posted: 05/03/23 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
The tape alone might provide plenty of gap. Don't need much.
Could take three layers of duct tape to create the gap.
* This post was edited 05/03/23 09:45pm by time2roll *
hotjag1
Posted: 05/03/23 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Close it with a little strip of paper or thin cloth etc. across the seal somewhere. Will prevent a tight seal and no suction.
I tried a piece of tape and the gasket sucked right up against it. Still very difficult to open.
