RV.Net Open Roads Forum: How critical is it to have a perfectly level trailer?
 > How critical is it to have a perfectly level trailer?
Page of 7
neu
Toronto
Posted: 05/04/23 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone,
I bought an adjustable trailer hitch, but I miscalculated and the maximum height is not enough to level the trailer. This hitch raises the height by 5 1/4 inches, but based on my calculations, I need an additional 1-2 inches of height to level the trailer. Is this critical or can I still tow the trailer as is?
UPDATE: I've read a few articles that say that I should better level it properly...
I don't know how to remove this question from the forum
* This post was edited 05/04/23 09:20pm by neu *
Posted: 05/05/23 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Ok there are a few reasons to want it more or less Level.. Perfect.. Well read on.
An RV Absorption Cooling Unit (Fridge) likes to be within 3 Degrees of level
What is 3 Degrees Well about 5" side to side. (that's a lot of slope)
Or 1 foot end to end for a 20' Trailer
Air conditioners condense moisture out of the air. if the Rig is "nose down" that condensate (As it is Tecnically called) may Drip down into the Living space instead of out on the roof to the ground.
And you won't be comfortable sleeping
Also if it's not "Square" the door may not open/close properly.
eHoefler
ozark mountains
Posted: 05/05/23 05:46am Link  |  Quote  |  Print  |  Notify Moderator
You better get an equalizing hitch! I'll bet you are over the towing capacity of you vehicle.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
way2roll
Wilmington NC
Posted: 05/05/23 05:47am Link  |  Quote  |  Print  |  Notify Moderator
If I understand your post you are wondering about how level it is when towing instead of parked. Parked, you want it level. Roads aren't level, at least not for very long. That said, it may affect your tow vehicle and it's capacity and how it handles.
2023 FR Sunseeker 2400B MBS
dougrainer
Carrolton, Texas
Posted: 05/05/23 07:08am Link  |  Quote  |  Print  |  Notify Moderator
LEVEL, or straight alignment between the vehicle and trailer gives you the strongest connection. Besides being level. You can "bend" a V. Harder to bend a -------- straight line connection. If you have to have a panic stop, you want the strongest connection. YES, you need a equalizer hitch connection. More expensive, but the SAFEST way to tow a trailer regardless of length or weight. Doug
BB_TX
McKinney, Texas
Posted: 05/05/23 08:06am Link  |  Quote  |  Print  |  Notify Moderator
You don't say what you are towing with, or what you are towing. My question: is the trailer tongue weight too much for your tow vehicle making the tow vehicle rear sag too much. You pictures don't show enough to tell.
valhalla360
No paticular place.
Posted: 05/05/23 08:37am Link  |  Quote  |  Print  |  Notify Moderator
^~this
While level is a general goal, it may be a symptom rather than a core issue.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
MitchF150
Puyallup, WA
Posted: 05/05/23 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Several things.. I think you are talking about it's towing level not parked once you get to your site.
Looks like you don't even have your propane cylinders installed yet. Those are going to add tongue weight.
You probably don't have the vehicle loaded for a weekend camping trip. People, stuff in the back, etc. Is the trailer loaded ready to camp too?
The receiver on the vehicle is probably not rated for a weight distributing hitch setup, neither is the vehicle, as it's just a uni-body SUV by the looks of it.
Your chains are still dragging, so you can 'twist' the links up to take up some of the length off, or have them cut to length and put on new hooks.
Might still be chewing off more than the vehicle can handle, but at least you are doing your homework first!
Good luck! Mitch
neu
Toronto
Posted: 05/05/23 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Good luck! Mitch
Yes, the question is about towing level, not parking on the spot.
Yes, indeed, my car was not loaded with items at the time of measurement. I measured the tongue weight, and it was 405 pounds without the propane tank. This weight falls within the limits of my car, which is a maximum of 440 pounds.
I will organize the items inside the trailer, and if the tongue weight exceeds the maximum limit for my car, then I will carry the propane tank in the car's trunk. I also still need to weigh the entire trailer to determine the percentage of tongue weight to the weight of the car. I will do this as soon as the hitch of greater height arrives.
I didn't take any photos, but the car didn't appear significantly sagged. I just have a very low trailer hitch attachment point.
The chains are not touching the ground, and there is a small distance between them. How much should I shorten the chains? In another forum thread, someone told me that the chains should hang but not touch the ground. What should be the distance between the ground and the chains?
Thanks!
neu
Toronto
Posted: 05/05/23 10:37am Link  |  Quote  |  Print  |  Notify Moderator
The car is sagging, but not too much.
I have an Audi Q5, and I understand that it is not the ideal car for towing a trailer, but the tongue weight at the time of the question was within the acceptable limits: 405 pounds out of a maximum of 440 pounds.
I do not plan to exceed the upper limit. In the worst case, I plan to carry the propane tank in the car's trunk or put something heavy behind the rear axle. I have not yet weighed the entire trailer to accurately answer this question.
Page of 7
