RV.Net Open Roads Forum: Carrier air v to advent a/c w/ harness
 > Carrier air v to advent a/c w/ harness
SDcampowneroperator
South Dakota
Posted: 05/06/23 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
The carrier died, just not cooling well. Research shows the advent will work fine with the carrier ceiling panel and remote wireless thermostat with the wiring adaptor.
In removing the carrier ( a 15k heat pump unit) a 2 wire sensor traced down from the unit into the circuit board with a connector to a jumper to a other connector to a led light.
As they are wired into the Carrier roof unit and no provision is given in the conversion instructions with the advent a/c I assume that wiring was for heaT hump operation temp sensors in the Carrier.
I am ready to plug in but hesitate as advent and etrailer.com do not address this
Advent is 13.5k a/c not a heatpump
Help please? Max
dedmiston
Coast to Coast
Administrator
Posted: 05/06/23 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from General.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Posted: 05/07/23 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I did a carrier A/C to Advent conversion There is one of the plugs that has to be changed (Poor Service Tech did not know how to install the Snap in socket.... Of course I did (I'm electronics trained).
Alas. the only "Senor" i know of in the Carrier is the frost sensor that you poke into the Evap coil... and of course the little Room temp senor that's mounted on the board (you don't plug it in it sticks out a hole in the cover)
Did not do a heat pump.. So don't know where it goes.
Itinerant1
Itinerant
Posted: 05/10/23 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info if my Carrier needs replacement.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
SDcampowneroperator
South Dakota
Posted: 05/10/23 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Problem solved, it is a temp sensor stuck into the evaporator coil fins. So just leave it plugged into the board and stick it into the advent evap. Fins.
Max
