haste maker wrote: Thanks for all the input on my generator problem, I have return home & have some tools to check thing with, & I found the slip rings in mine are black not copper, I am going to order the Slick Slick from Flight Systems & clean these rings.
A piece of green scotch bright wrapped around the flat end of a carpenters pencil, will accomplish the same thing.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
I have a onan diesel generator and it did the same thing know one could figure it out. I found out I had a hairline crack in the fuel line I ran a separate line from a gas can and its been running ever since.
I cleaned the slip rings, and removed some oil...I was told that some of the Onans had the wrong oil drip stick in them...I did a test run for 20 hours with both AC's turned on without any problems...Thanks to everyone for the advice...
