RV.Net Open Roads Forum: Towing: Fuel Ecomony - Towing
Search only in Towing
Open Roads Forum  >  Towing
 > Fuel Ecomony - Towing
Page of 5
pianotuna
Regina, SK, Canada
Posted: 05/08/23 12:42am Link  |  Quote  |  Print  |  Notify Moderator
bob213 wrote:
pianotuna wrote:
Consider adding air tabs.
Save your money and buy gas. If vortex generators actually improved fuel economy I think every 18 wheeler in the country would have them.
Many trucks do have vortex generators. Just not air tabs.
They do save on gas when there is a tail wind.
They also dramatically improve the noise level in a class C.
Regards, Don
twodownzero
NM
Posted: 05/08/23 11:32am Link  |  Quote  |  Print  |  Notify Moderator
You should expect the same fuel economy with the new truck as with the previous one. Fuel is just energy. A 3/4 ton truck is slightly heavier but the difference is minimal.
If the new truck has more horsepower and you use it, you will use more fuel. But modern 1/2 tons have a ton of power, so I doubt that'll matter.
The modest weight difference doesn't really matter either.
bikendan
Goodyear, Arizona
Posted: 05/08/23 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
289457 wrote:
Thanks to all for your replies. The concern with fuel economy is not cost, but range. Trying to gain some confidence that a new gas 3/4 ton (probably Ford or GM) and leaning toward a Silverado w/ 6.6L and 3.73 rear end will go farther on a 34 gallon (or so) tank than the current truck takes me on a 25 gallon tank.
Then get a F150 XLT 3.5 Ecoboost with Max Tow package. Gets you a 36 gallon fuel tank. Mixed mpg- 16+, Highway mpg- 19-20
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Cptnvideo
Arizona - most of the time
Posted: 05/08/23 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
If the OP really wants to increase range, put a 50 gallon aux tank in the pickup bed.
We have one along with 32 gallon OEM tank, range 650 miles towing our 42' 5th.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
OutdoorPhotographer
Arizona
Posted: 05/08/23 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure you will generally get a bigger tank with 3/4 or 1 ton. My F250 has a bigger tank than my F150 did. Lots of variance by year and model.
I regret not buying a SRW F350. No size difference from F250 and both or rough daily drivers as a Super Duty but the extra payload is nice. If you decide diesel, definitely go with one ton because the heavier diesel will negate much of your payload gains with the 3/4 ton.
I'm not a fan of towing with half tons but they really have gained capabilities in recent years, at least regarding a 7500 lb TT so they might be a model out there that suits your needs.
2008 Rockwood Signature Ultralite 5th Wheel
F-250 6.2 Gasser
Former PUP camper (Rockwood Popup Freedom 1980)
way2roll
Wilmington NC
Posted: 05/08/23 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
My 2020 F350 SRW had a 48 gal tank. Loved the extra range it offered. But you are right, as a daily driver they're not a lot of fun.
2023 FR Sunseeker 2400B MBS
deltabravo
Spokane, WA
Posted: 05/09/23 07:05am Link  |  Quote  |  Print  |  Notify Moderator
A long time friend once said "People that get concerned about fuel economy when towing probably can't afford to RV in the first place."
* This post was edited 05/11/23 09:47pm by deltabravo *
way2roll
Wilmington NC
Posted: 05/09/23 07:33am Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
A long time friend once said "People that get concerned about "fuel economy" with towing, or upgrading to a different vehicle probably can't afford to RV in the first place."
Concerns with range are a lot different than concerns with cost of fuel. A more efficient vehicle and/or one with a larger tank can make a big difference in how and the ease in your travel. And are you trying to imply that folks upgrading to a different vehicle are trying to save money?
StirCrazy
Kamloops, BC, Canada
Posted: 05/09/23 08:22am Link  |  Quote  |  Print  |  Notify Moderator
if your worried about range, go with the diesel. better MPG directly relates to more range. empty the gassers might get decent milage but loaded up they fall far short of the diesel
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Posted: 05/09/23 09:48am Link  |  Quote  |  Print  |  Notify Moderator
And still under 10 towing. What was your point?
The Ecoboost is no more fuel efficient loaded or empty than any of the V8 gasser counterparts.
Page of 5
