TurnThePage
North ID
Instead of hanging the macerator off the black/gray drain, can I add a couple feet of hose between them, allowing the macerator to set on the ground? Any reason not to?
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Boon Docker
I added 3 feet of hose to my macerator and it works just fine.
TurnThePage
North ID
Thanks for the feedback!
Boon Docker
You're Welcome
bucky
Raleigh metro
That's a great idea. Thanks for sharing.
Puma 30RKSS
Done it up to around 30 feet on one occasion. (Had to use a portable battery for the pump).
At least one model comes with a short length of 3" hose on the inlet (This model is mounted in the RV.. gives you the choice of using the pump or a straight 3" stinky slinky).
Boomerweps
Hills of PA
My only concern would be getting that regular sewer hose fully drained, plus an extra item to clean.
But mechanically using it that way, no problem.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
TurnThePage
North ID
Is it silly to worry about the weight of the macerator hanging off the drain?
Bobbo
Wherever I park
I think it is. Now, if you were driving down the road with it hanging on there, I would give a different answer. Driving down the road, when you hit speed bumps or potholes, you have a dynamic load that is many times higher than just the weight of the macerator hanging on there while it is sitting still.
Bobbo and Lin
Cummins12V98
on the road
I like having a clear elbow before so you and see when it's almost drained.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
