RV.Net Open Roads Forum: Fifth-Wheels: Broken Leaf Spring
 > Broken Leaf Spring
Cummins12V98
on the road
Posted: 05/09/23 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Northern Tool sells US Made springs, check it out.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Platte City, MO
Posted: 05/09/23 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I've had good luck with Etrailer. But sometimes I've also found better prices when I shopped around. Just depends.
Just a heads-up: if you go to heavier springs, you may need to get longer U-bolts.
Howard and Peggy
"Don't Panic"
JKJavelin
Milwaukee, WI
Posted: 05/10/23 07:51am Link  |  Quote  |  Print  |  Notify Moderator
FYI, a friend of mine got his springs from etrailer last year and they were stamped Made in China.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 75 Nights
ScottMT
Montana
Posted: 05/10/23 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
So I finally pulled the good spring off... measures out to 25.25 eye to eye. Gonna need new shoulders bolts anyway as those mostly were trashed removing them, I plan on a wet bolt/shackle kit anyway.
The stamping on the spring band was:
RA 93115
7 29 04
I might assume the second number is the date it was stamped
A search does bring back a matching hit:
https://standardaxle.ca/product/spring-25-70-4-leaves-72-26a-sup/
But those are rated at 3K, so, who knows. The number I found on the axle was 5200. The number on the RV is 5080 per axle, so, ha, none of it lines up. Either way I think I'm going with 3K springs.
* This post was edited 05/10/23 01:07pm by ScottMT *
Allworth
Orlando, FL
Posted: 05/10/23 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
3K per spring is 6K per axle which is more then 5.2K per axle which is more than 5.02K max load!!!
You should NEVER run at max load anyway.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
ScottMT
Montana
Posted: 05/10/23 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I hear you... I think I'm safe going with more spring, but I agree, the numbers don't line up, and I don't plan to overload it, I just don't want the springs to break again.
It turns out, the RV industry can design their GVWR based pin weight supported... so, GVWR of 12K, with a 2K tongue weight supported by the tow rig means they can legally sell a 12k GVWR RV with tandem 5K axles.
In a way it makes sense, but it still doesn't seem smart to me to be running maxed out all the time. They are 3" axles, as are most 6K axles. AL-KO is the brand.
Cummins12V98
on the road
Posted: 05/10/23 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Stick with the same spring capacity but spend the $$$ for US Made.
ScottMT
Montana
Posted: 05/10/23 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Oh I'd prefer to buy American, but where? Kinda hard to find now
* This post was edited 05/11/23 07:34am by ScottMT *
fj12ryder
Platte City, MO
Posted: 05/10/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
And no guarantee that even if it's supposed to be made in America, it won't say Made in China when you actually get it. You're doing what I would be doing.
ScottMT
Montana
Posted: 05/11/23 07:57am Link  |  Quote  |  Print  |  Notify Moderator
It turns out, when I search for "93115" springs, they are sometimes 25.25, and sometimes 25.13 (or shown as 25 1/4, I'll assume there is rounding in the first number).
The examples are always 4 leaf springs rated at 3,000 lbs each. They get away with a 4 leaf spring because it has thicker leaves than the 5 leaf springs. I'm not sure if one is really better than the other.
I'm also not 100% sure mine measure out to 25.25, or 25.13, with a tape measure it is easy to be off by a 16th, these maybe fall in the middle somewhere, but they are 19 years old, and maybe at this point we are splitting hairs. The longer length at best adds 1/16 on either end of the spring.
Interestingly enough, you can find a set of 4 on amazon, haha:
4 Leaf Spring Set
They are stupid cheap at $40 a each shipped, so I'm going to assume those are the worst china has to offer.
I'll continue the search to find the best quality, but it is a trick to know what you're even ordering now. It seems dexter/rockwell is still american made, but can't seem to find them to order online.
I need to get this order done today so I can get them in by next weekend.
