GaryS1953
Michigan
Hi All - So my new (to me) camper has Diflex 2 roof. Could I put those drill free plastic mounts on this kind of roof, and should I? I'd rather not put holes in the roof if I can avoid it. What is the consensus on those glue on mounts? Do they hold up well?
https://www.amazon.com/Spartan-Power-Drill-Trailers-Skoolies/dp/B0B43VGFQZ/ref=sr_1_11?crid=24IIFRUYY96GR&keywords=solar%2Bpanel%2Bmounts%2Bfor%2Brv%2Broof&qid=1683585001&sprefix=Solar%2BPanel%2Bmounts%2B%2Caps%2C122&sr=8-11&th=1
Thanks!
edited 05/08/23 05:39pm by GaryS1953 *
Gary in Michigan
2014 Chevy Silverado 1500 Double Cab 5.3 Liter V8
1996 Coachmen Catalina RB210 21' Fifth Wheel
495 Watts Solar, 40 AMP Renogy Tracer MPPT Controller,2 GC2 6V Batts.
Boon Docker
^ Link For The Above ^
StirCrazy
Kamloops, BC, Canada
Personally, I would never rely just on those, especially on a rv roof. people have put them down with two-sided tape, but I say just screw in. make sure your on studs, squirt roof sealant into the holes before you drive the screw in then use a self-leveling sealant over top and it won't be an issue
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
opnspaces
San Diego Ca
Interesting idea. I don't like the fact that they are hollow on the bottom giving a small surface area for adhesive though.
On a positive they look like a not previously thought of good candidate for my 3d printer.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
TechWriter
Part-Timing Again
Shortening Amazon links . . .
This:
Becomes:
All the **** after .../B0B43VGFQZ/ gets cut
Becomes:
Clickable Link
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
