RV.Net Open Roads Forum: Travel Trailers: Rooftop AC Unit Not Cooling Well
 > Rooftop AC Unit Not Cooling Well
poppa
Dallas, TX
Posted: 05/15/23 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
my less than three year old rooftop slowly quit cooling new aint always better. put a tap on the suction line and put some snake oil leak stop in it with refrigerant and still cooling. cant, couldnt find leak but so far so good. was able to do it my self though.
stripit
Prescott
Posted: 05/16/23 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Way back when we had a travel trailer the roof a/c was to us pretty poor. Decided to remove the ceiling a/c cover and have a look. Seems a divider panel slipped out of the way allowing the hot return air to mix with the cold discharge air. Slid that divider back into place, used some aluminum tape to seal the various holes in the unit that would still let air to mix and wow it fixed the a/c unit. Might want to look into yours to just see if it was a simple slip of the divider. Good luck
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
Raven33
OR
Posted: 05/16/23 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all of your replies and advice. I had a mobile RV guy come out and take a look today. He said everything seemed to be in good working condition but it was filthy and needed to be cleaned. Definitely seems to be cooling better now. Glad I don't need a new AC yet. I also had him fix a few other things that needed repair, so hopefully I should be good to go for a while. Nice to find an honest tech who charges reasonable rates.
MFL
Midwest
Posted: 05/16/23 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you got it cooling again! Nice to get a few issues resolved also, while you have a good mobile tech to inspect. Added confidence in your rig gained, and at a reasonable price too! [emoticon]
Thanks for posting your outcome,
Jerry
debrhardt
wisconsin
Posted: 06/13/23 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
what are you plugged into? is your compressor kicking in. you need about 15-18 amps to start the compressor decently. running it on low amps kills compressors.
plug into 30 amps.
