TechWriter
Part-Timing Again
Just started happening . . .
One side of our slide out went out crooked. To keep the side out even, I had to push on one side from the outside while my wife brought the side in.
The same now goes for pushing one side OUT.
This is getting old. What to do? We leave on a long trip Sunday.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
CA Traveler
The Western States
Obstruction, loose mounts, bad roller, seals, single/dual motors etc are possibilities. Mechanism type/model can help.
For Sunday travel maybe a mobile tech?
2014 Grand Cherokee Overland
Bob
nickthehunter
Midwest
Try this Clicky
John Wayne
Long Beach, Ca
Well if your sea View is like mine and you are talking about the dinning area slide it only has 1 motor that connects the two gears. On mine I sometimes have the bolt on the front tube that turns the gear break. it's a round rod that goes into a square tube. The rod that runs from the motor to the front is the only thing that ties the two gears together so they both run out at the same time. It's possible you have skipped a tooth or two on the cogged rail that the gear turns you. You can see the rail and gears when you open the storage bays.
Try releasing the motor brake and pushing the slide all the way in then resetting the brake. The brake is the lever that sticks up on the side of the motor.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
