Cummins12V98
on the road
The B&W RVK3600 for the RAM with pucks system weighs a total of 215# of that the removable head weighs 75# and the base weighs 140#.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Platte City, MO
Cummins12V98 wrote: Showme 5vr wrote: Just got a new truck with the puck system. Bought a B&W Companion hitch that weighs about 230 pounds. What have those of you that have a similar hitch done to remove the hitch without straining your back.
First remove the head from the base. Now release the pucks and lift and slide the base to the edge of the tail gate. Stand on the ground at the tailgate and remove, EZ-PEE-ZEE. If you think it's EZ-PEE-ZEE, you're the manly man. Too much for me, and that's a fact.
Howard and Peggy
"Don't Panic"
RCMAN46
NorthWest
Learjet wrote: The Ram base is bigger and heavier than the Ford or Chevy.
I take the head off and then two person lift the base. I've done it by myself but that is asking for it...don't do that.
Now to do it by myself safely...I used a coupon and got a $100 engine hoist from Harbor freight. I still have to slide or walk it closer to the edge of the truck...then using one of these Link... I can lift the whole hitch out.
Some leave the hitch attached to the trailer and use the trailer to lift the hitch and then drive out from under the hitch while attached to trailer....then reverse the process to hook back up.
I use the harbor freight engine hoist. I got an extension square tube from my local metal supplier. Then I can reach my Reese puck style hitch and not have to remove the head. The hoist can handle the weight with the extension.
When at a campground for extended time periods I leave the hitch attached to the trailer and remove that way.
sayoung
Tx
I used a homemade lift eye that I used my tractors loader to set in & out. I had the 18k Patriot which I could get the sections out by hand but I'm 74 so why not use the machines I have. I use this same rig to get my AirSafe hitch in/out & I won't attempt to load it by hand.
Cummins12V98
on the road
fj12ryder wrote: Cummins12V98 wrote: Showme 5vr wrote: Just got a new truck with the puck system. Bought a B&W Companion hitch that weighs about 230 pounds. What have those of you that have a similar hitch done to remove the hitch without straining your back.
First remove the head from the base. Now release the pucks and lift and slide the base to the edge of the tail gate. Stand on the ground at the tailgate and remove, EZ-PEE-ZEE. If you think it's EZ-PEE-ZEE, you're the manly man. Too much for me, and that's a fact. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
It's all in how you handle it. Take the short end and pull it out and down onto a cart then drop the other end. NOT needed to actually pick up the 140#. I would pull it into my body and slowly lower it to the ground. In Construction you learn how to handle heavy items safely.
fj12ryder
Platte City, MO
Okay, gotcha. Just kind of manhandle it to where you can drop one end. That works.
Likes to tow
Huntington WV
The base to my Ford hitch does not look like this one. I can see this would weigh much more and would require a different approach.
Cummins12V98
on the road
Yes the ford has a small footprint. I am surprised they have not widened the stance of their base connections.
edited 06/02/23 08:29am by an administrator/moderator *
CaLBaR
Ontario, Canada
garyp4951 wrote: I installed an electric hoist in my garage and store the hitch on a 4 wheel dolly.
This is exaclty what I did and works great!!
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
laknox
Arizona
I used to use a cheap engine hoist and furniture dolly (Harbor Freight), then I got a gym rat of a son-in-law. 'Nuff said. :-)
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
