RV.Net Open Roads Forum: Fifth-Wheels: keystone Sprinter quality??
 > keystone Sprinter quality??
troy t
home
Posted: 05/11/23 09:22am Link  |  Print  |  Notify Moderator
We are in the process of shopping for a used 5th wheel. We are going to look at a 2017 Keystone Sprinter 297FWRLS. I searched the forums but didn't find much information about the Sprinter model. How are Keystones as far as quality holding up out there? Does anybody have this particular model?
I'm a bit jaded on the used market as we really had a bad experience with the last used unit we bought but the new market is a bit out of reach for us right now.
midnightsadie
ohio
Posted: 05/11/23 03:48pm Link  |  Print  |  Notify Moderator
little shy about buying? hire a rv inspector . your local rv dealer should know one. they,ll find things you never would have though of. ain,t that exspense
Curly2001
Tucson, Arizona
Posted: 05/11/23 04:37pm Link  |  Print  |  Notify Moderator
Just be sure you look for water damage in the walls and the roof area. Look at the suspension, springs, axles, and the floor to make sure it is all straight. If you can get an inspection from an independent repair shop that would be good, too. That model year should be built pretty well since it is before the Covid builds which I am finding are pretty much thrown together. Good luck,
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
RetiredRealtorRick
St. Augustine Beach, FL
Posted: 05/12/23 05:09am Link  |  Print  |  Notify Moderator
Keystone is a Thor product.
. . . never confuse education with intelligence, nor motion with progress
TXiceman
Bryan, TX
Posted: 05/12/23 11:55pm Link  |  Print  |  Notify Moderator
Keystone sprinter is an entry level trailer and on a Lippert frame. It will be close on tire and axle capacity. The spring and spring hangers are minimal. First hire you own professional inspector to go over the unit and see that all systems are working and there is no water intrusion present or past.
A 2017 trailer may have tires that are aged out so check the DOT date codes for all tires. Typically trailer tires are replaced at 5 to 6 years. Do not accept cheap Chines tires. Insist on AMerican made tires.
Ken
Amateur Radio Operator.
2013 HitchHiker 38RLRSB Champagne (FORSALE), toted with a 2012, F350, 6.7L PSD, Crewcab, dually. 3.73 axle (truck is sold), FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
CWilson
Beach
Posted: 05/13/23 06:21am Link  |  Print  |  Notify Moderator
So is Airstream, and Tiffin. DRV? Jayco?
troy t
home
Posted: 05/13/23 06:22pm Link  |  Print  |  Notify Moderator
So we looked at the trailer today and it was very well taken care of. However when I went on the roof all three slides had the roof membrane pinched and tore so there was a small hole in each one, right in the center at the outer edge. The wood underneath was wet and that was part of the issue with my old camper was a bad roof so I didn’t want to get into that again. We’ll keep looking. Thanks for all the advice.
laknox
Arizona
Posted: 05/15/23 05:11pm Link  |  Print  |  Notify Moderator
What ^^he^^ said. Contact NRVIA.org for a certified inspector near the rig you're interested in.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
laknox
Arizona
Posted: 05/15/23 05:12pm Link  |  Print  |  Notify Moderator
Curly
Don't forget to check the floors for soft spots, especially around the toilet, shower, lav, kitchen sink and in the slides.
Lyle
BarneyS
S.E. Lower Michigan
Posted: 05/17/23 07:57am Link  |  Print  |  Notify Moderator
For all those who do not read previous posts in a thread, the OP said he is moving on. The trailer in question had water damage in the roof after he inspected it.
Thread closed.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
