rmnpcolorado
Madison, WI
Here’s a weird deal that I’ve never run across before. We brought our trailer home for the summer and are ready to go out on our first weekend voyage and the button actions are backwards. Slide in sends the slide out, retract extends the tongue jacks. We’ve fried two 40amp fuses, which leads me to believe that something’s crossed, so we have no fridge power or lights. Thoughts?
2020 Ford F-150 3.5L w/Max Tow
2023 Riverside RV Intrepid 240BHi
nickthehunter
Midwest
You got the battery hooked up correctly?
Bobbo
Wherever I park
I agree. The battery is wired backward.
Bobbo and Lin
rmnpcolorado
Madison, WI
I think you’re exactly right, as when I disconnected the battery, replaced the fuses, and powered back up, all was good.
Now to figure out how I messed that up. I’ve only done this how many times before…
midnightsadie
ohio
could be a senior momment, we all have them .lucky you didn,t fry a lot of things.
rmnpcolorado
Madison, WI
So to clarify, I had the large wires correct-white on positive, black on negative. But what about the little wires? I had the white on positive and the red with the inline fuse on negative.
BB_TX
McKinney, Texas
Can’t think of any possible reason to have a fused wire on the negative post.
Typically there is one large wire on the negative post going to your metal frame for all grounding. The positive post will typically have one large wire connected and possibly a couple or more smaller wires often with in-line fuses connected directly or indirectly to that positive post.
opnspaces
San Diego Ca
I think he's describing his mis wire. the red with the fuse is positive. In fact any wire with a fuse near the battery is positive.
All the white wires are negative. You'll have to trace the small wires. Could be positive for the tongue jack. Or could be positive for the emergency breakaway switch.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
CA Traveler
The Western States
OP What you have learned is that DC motors turn in the opposite direction when the polarity is reversed.
Check everything especially items you don't use often and have a great trip.
2014 Grand Cherokee Overland
Bob
JRscooby
Indepmo
rmnpcolorado wrote: So to clarify, I had the large wires correct-white on positive, black on negative. But what about the little wires? I had the white on positive and the red with the inline fuse on negative.
I think right here is the problem. On all RVs I have messed with white is ground for the house part.
