RV.Net Open Roads Forum: Travel Trailers: Backwards buttons
 > Backwards buttons
Boomerweps
Hills of PA
Posted: 05/12/23 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Confusion sometimes occur from people working on house electric and mobile electric. House electric BLACK is hot, white is neutral or return, green is ground. Mobile 12vdc RED is hot/positive and black is return/negative/ground.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
4x4van
California
Posted: 05/12/23 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
And to make it even more confusing, many RVs use yellow as positive and white as negative!
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
JRscooby
Indepmo
Posted: 05/12/23 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have not worked on all that many campers, but every one I have used white for ground. Now the positive, I have seen black, red, and brown. Yellow is new to me, but I would accept the possibility.
OP, Disconnect the battery, grab your Ohm meter, and check for continuity frame/end of white wire.
Reversed polarity is all that is needed to reverse direction a DC motor runs. And reversed polarity will blow fuse to protect the converter.
stickdog
Somewhere, USA
Posted: 05/12/23 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've learned pictures are better than my memory.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Huntindog
Phoenix AZ
Posted: 05/12/23 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
rmnpcolorado wrote:
I think you’re exactly right, as when I disconnected the battery, replaced the fuses, and powered back up, all was good.
Now to figure out how I messed that up. I’ve only done this how many times before…
You probably blew the fuses on the convertor. There is ususally 4 of them IIRC. They are there just for when the battery is hooked up backwards. To prevent future brain farts, only dissconect 1 battery cable.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Fizz
Ottawa, Canada
Posted: 05/12/23 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
YUP!
Got a new boat last year. When I winterized it I saw the mess of wires going to the battery. Good thing I took a picture because I would have been lost this Spring trying to get it right.
JRscooby
Indepmo
Posted: 05/13/23 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Few inches of duct tape, make a flag large enough to write positive or negative with sharpie.
rmnpcolorado
Madison, WI
Posted: 05/13/23 08:46am Link  |  Quote  |  Print  |  Notify Moderator
For everyone wondering, it was that I indeed had the wires backwards. Black to positive, white to negative and all is well again. We take the battery completely off in wintertime and keep it in our basement. Even though I try to leave the wires on their respective sides, I suspect that when it was moved in and out of the shed they shifted and I didn’t think about it until I had no power. I’m still trying to figure out which one is supposed to have the inline fuse though, as it’s a red wire. I’m assuming positive. I want to make tags to identify them right on the wires.
2020 Ford F-150 3.5L w/Max Tow
2023 Riverside RV Intrepid 240BHi
CA Traveler
The Western States
Posted: 05/13/23 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
And then take and retain pictures.
2014 Grand Cherokee Overland
Bob
Bobbo
Wherever I park
Posted: 05/13/23 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Take green electrical tape and wrap it around the ground wires. Take red electrical tape and wrap it around the hot wires. Taking photos is great, as long as you can find the photos.
Bobbo and Lin
 > Backwards buttons
