RV.Net Open Roads Forum: Travel Trailers: Backwards buttons
 > Backwards buttons
JRscooby
Indepmo
Posted: 05/14/23 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Bobbo wrote:
Take green electrical tape and wrap it around the ground wires. Take red electrical tape and wrap it around the hot wires. Taking photos is great, as long as you can find the photos.
Then you will have any RV professional that needs to work on it in the future confused. If you want to mark with color, use industry standard. Yes, I understand green is ground when working with AC, you hamn sure do not want to ground AC to the battery. The fact we often use frame for negative on many DC circuits leads to careless use of language when AC and DC are used on same vehicle.
rmnpcolorado wrote:
For everyone wondering, it was that I indeed had the wires backwards. Black to positive, white to negative and all is well again. We take the battery completely off in wintertime and keep it in our basement. Even though I try to leave the wires on their respective sides, I suspect that when it was moved in and out of the shed they shifted and I didn’t think about it until I had no power. I’m still trying to figure out which one is supposed to have the inline fuse though, as it’s a red wire. I’m assuming positive. I want to make tags to identify them right on the wires.
Thank you for telling us you found the problem. It is very likely the fact of the mistake will be all the memory aid you need. But in my world everybody has duct tape, and most have a sharpie.
Few inches of duct tape, make a flag large enough to write positive or negative with sharpie
 > Backwards buttons
