synergy_58
On the road again!
synergy_58 wrote: BarneyS wrote: You said, "I do not yet have a brake controller or a distribution hitch. I need recommendations for these.
I will have to drive it home under standard towing set up, about 60 miles in fast moving, heavy traffic, mostly level with a few small hills, to get it home. Once home it will sit until I can get it cleaned up and set up the way my wife and I want it. I will then install a brake controller and buy a distribution hitch."
Dont take it on the road at all without a brake controller installed! You will be breaking the law and putting yourself and others in danger.
The Tekonsha Prodigy P3 brake controller are plug and play because it comes with the wiring harness for your truck from that retailer. Note: Don't try and save a few bucks by getting a "time delay" controller.
One more comment. You will most likely be at the limit of your truck with that trailer. I would not pull it without a WD hitch. They are not very expensive and also very easy to install. Get one like this and be safe - at least equipment wise. Good luck and I hope you enjoy your trailer. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Barney
Thanks! Ok, so I'll get the brake controller done, and buy the WD hitch before I get the TT. Actually, IF I get this one. The seller is already telling tales.
Wife and I really like the floor plan in this 22'er; however, the weight is right at the line with no comfort zone, so we're going to keep looking, which is unfortunate because going shorter means less room. Maybe we need a newer truck. IDK. Maybe we can find a 19, 20'er, and it would be better. IDK.
[img/Users/Frank/Pictures/iPhoto Library_2/Originals/2014/Apr 2, 2014/2009_1306_Nav_BlueMoon.jpg[img]
Note: Due to invalid formatting, all formatting has been ignored.
cptqueeg
Idaho
synergy_58 wrote: cptqueeg wrote: synergy_58 wrote:
3. What should I check on this TT, any inherent issues with a Nash build?
The bed is only a residential full size - 54" wide, so that would be a hard no unless I was single.
When you up graded springs did you get higher load range tires?
Yes, Im running Toyo Open Country AT III's, load range E. They are awesome tires!
Have the same on my Tundra.
Huntindog
Phoenix AZ
Barney
Thanks! Ok, so I'll get the brake controller done, and buy the WD hitch before I get the TT. Actually, IF I get this one. The seller is already telling tales. What do you mean by "telling tales?
From what you have posted, it sounds like a good deal. Check out the roof. If that is good, buy it. Lots of used junk out there in that price point.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
spoon059
Just north of D.C.
I made a little "wall" with either a 2x8 or 2x10 (I can't remember the width of the little gap between the wall and the mattress) and we installed a memory foam Queen bed in that space. Had to cut a notch out up front to open the cabinet and had to climb into bed from the foot side, but widened the bed enough to make it comfy for 2 adults (And 3 little dogs).
2015 Ram CTD
2015 Jayco 29QBS
cptqueeg
Idaho
Sounds like a perfect solution! I've got a narrow sleeping arrangement in my van so I sleep in a tent if stopped for more than a night.
edited 05/23/23 08:34am by an administrator/moderator *
synergy_58
On the road again!
The Nash was worn out underneath, frame rusty, cabinets worn, tub had a cracked corner and caulked up, and of course it needed a major detail. I liked the floor plan, the weight was border line.
