wldlfnutz
Homer Glen, Illinois
Where is the hot water heater bypass on the Cougar 22mls?
BarneyS
S.E. Lower Michigan
Should be a single valve or a triple set of them right in front of or behind the water heater. I have never seen a bypass located in any other location other than right around the heater.
Barney
Single valve bypass
![[image]](https://i.imgur.com/nhmP5GIl.jpg)
Two valve bypass
![[image]](https://i.imgur.com/og5A3JBl.jpg)
Three valve bypass
edited 05/15/23 08:47am by BarneyS *
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
wing_zealot
East of the Mississippi
There is likely a panel inside the trailer with two screws holding it on that needs to be removed to find the valves. These valves are located on the (front) side of the water heater, not the back side (which is visible from outside the trailer) - that is likely why you don't readily see the vavles.
