RV.Net Open Roads Forum: Towing: Sway Bars
Search only in Towing
Open Roads Forum  >  Towing
 > Sway Bars
BarneyS
S.E. Lower Michigan
Posted: 05/22/23 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Snip...
However your trailer is SO small compared to your TV that you may actually get others to tell you you don’t need it…..if they can stay on topic.
(Like the post above mine explaining hitch types….lol)
Snip...
Why don't you read the post before you shoot off your mouth. I was responding to his last comment in the post above mine. Here is what he said.
"Maybe a discussion of the difference between sway bars and weight distribution systems."
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Reisender
NA
Posted: 05/22/23 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Try it without and see how it goes. We don’t use a weight distribution hitch (what I think you are calling sway bars). Our trailer is 3400 fully loaded. No issues. Tows solid and no squat on the car. Give it a shot and make a decision from there. It’s nice to not have to deal with a WDH. Takes 60 seconds to hook or unhook.
dodge guy
Bartlett IL
Posted: 05/23/23 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I still don’t see where the OP has distinguished between sway bar and WD bars.
N his opening post he said he had sway bars on his bigger trailer. We would have to assume he is talking about WD bars. That said, he probably doesn’t need a WD hitch, but a sway bar would be recommended!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Posted: 05/23/23 10:47am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
Grit dog wrote:
Snip...
Snip...
Barney
No shooting off…I don’t and he don’t need either or with a dinky trailer behind a big truck.
But rather than get bogged down in being “right” about the OPs terminology and showing him how (y’all know the difference…good for you), I cut to the chase.
Next caller please…..
PS I wasn’t trying to single you out. But only to cut the BS out.
Posted: 05/23/23 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Now, OP, you left out the most important part. You have a new trailer. You have a truck.
How did the trailer get home? Did you tow it? How did it tow?
That’s where you should be going first…. Not the salesman recommendations. If you got 5 bucks in your pocket, the butcher is still gonna recommend getting a filet, even if you only need to make a couple cheeseburgers. It’s his job to sell you chit whether you need it or not.
Dont be a sucker for salesmen.
And especially don’t be a sucker for hitch accessories. Half the time they’re like the “interior protection package” you get offered with a new car. Largely useless except for extracting money out of your wallet.
Now go take the trailer for a rip down the freeway and come back and tell us if it was scary, bumpy, swervy, or just fine.
Betting the latter….good luck!
StirCrazy
Kamloops, BC, Canada
Posted: 05/24/23 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
BarneyS wrote:
Grit dog wrote:
Snip...
Snip...
Barney
but it's always those small trailers that go snaky the fastest as they are easier to load improperly. I used to have one of those little chalet "a frame" trailers when I first started RVing when I was 16. took a while to figure out how to lad it properly so it wouldn't act like a snake tail behind the Camaro [emoticon] when you don't have a lot of space it's hard to get that proper weight up front.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
mkirsch
Rochester, NY
Posted: 05/24/23 08:24am Link  |  Quote  |  Print  |  Notify Moderator
BIG assumption that he doesn't need a sway bar. Some might say dangerous.
The trailer never decides to get squirrelly 5 miles from home. It's always the farthest from home, the farthest from help. Buddy of mine towed for years same truck and trailer, all of a sudden he's driving like a bat outta hades down I-81 and the trailer starts trying to pass him. Of course clueless macho man he taps the brakes, thinks nothing of it, and continues on his way. Imagine if it had scared the tar outta him like it should have, and he immediately pulled over and refused to drive any farther. Now what? Out in the middle of nowhere, far from home, far from help, nothing to fix the problem (there was nothing heavy to put in the front of the trailer). Cheap sway bar already installed would have prevented the problem in the first place.
Reisender
NA
Posted: 05/24/23 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Also keep in mind that some trailers and or compact SUV’s don’t allow or recommend weight distribution hitches because of their design. Both our SUV and trailer are like this. We don’t need then anyway but just saying. Read the manual.
deltabravo
Spokane, WA
Posted: 05/27/23 09:03am Link  |  Quote  |  Print  |  Notify Moderator
fwed wrote:
I'm thinking sway bars.
A sway bar is something that goes on the tow vehicle - generally bolt to the rear axle and the truck frame.
The device you are referring to as part of the trailer hitch is a sway control device of some sort.
opnspaces
San Diego Ca
Posted: 05/27/23 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
It's a small popup trailer behind an F150. You definitely do not need to add weight distribution (spring bars) to the hitch.
As far as a sway bar. If you load the Aliner properly with the majority of the added weight at or in front of the axle then probably not.
If you get too much wiggle when towing, or you have to put too much weight behind the axle the yes I would get a standard inexpensive sway bar. Barney posted a picture of one above called a Friction Sway Control. But I would just tow it first and see how it performs before adding anything to it.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
 > Sway Bars
