Chum lee
Albuquerque, NM
Another thing to consider is the "relative quiet" of your generator. For example, if you measure the relative ambient background dB before you start your generator and it's quite high, for example, you are at the beach, an airshow, a NASCAR event infield, or near a major highway, your generator may seem very quiet. But if you are at a place like Chaco Canyon where at night you can hear rabbits scampering about 100' away, (read: dead quiet) even the quietest generator can seem obnoxious.
Chum lee
ScottG
Bothell Wa.
When it's making power for you it's a lot more quiet than it is for your neighbor.
routeforty
ohio
bgum wrote: Westinghouse igen4500
$699 now on sale at Home depot. Electric start that's what I have. We have lake property where we use it. Sits about 25-30' from camper, With the windows closed you have to listen for it. With windows open you can hear it, but it is no distraction. Thinking of putting a box around it. Then you probably would forget it's running. Gary
2018 coachmen leprechaun class c 2008 KZ spree 260FL
swimmer_spe
Sudbury, Ontario, Canada
jjrbus wrote: I find the dB ratings to be misleading, not useless. Some sounds within a rating can be more annoying. Then "quiet" generator is relative, A quiet Honda generator is quiet compared to an open frame construction generator. But hardly quiet.
What I speak of is that.... You can carry on a conversation around the Honda ones.Good luck doing that to a Champion.
swimmer_spe
ScottG wrote: When it's making power for you it's a lot more quiet than it is for your neighbor.
Where I'll be using it, there will be others around. My goal is not not know mine is running, except for the ice cold AC.
cptqueeg
Idaho
jjj wrote: I just heard my brothers 3500 Harbor Freight Predator just the other day and I was really impressed with how quiet it was. I have 2 Honda 2000's and I swear it was possibly a little quieter then my 1 Honda alone. I wish they would come out with a dual fuel as I want to dump the Hondas so I do not have to carry fuel. I always have 2 extra propane tanks with me and don't have to worry about gas.
Dutch Mountain offers dual/tri fuel retro fit kits for your Honda's. I adapted mine and it's sweet, although it can go through some propane.
Quality equipment from quality people.
valhalla360
No paticular place.
routeforty wrote: We have lake property where we use it. Sits about 25-30' from camper, With the windows closed you have to listen for it. With windows open you can hear it, but it is no distraction. Thinking of putting a box around it. Then you probably would forget it's running. Gary
I was playing around last summer with our Champion 4500 dual fuel. We were in a site that backs up onto a valley, so no one behind us. I just put a 4x4 piece of plywood propped up in front of it.
Went from barely heard at the road in front of the camper to I couldn't hear it.
A box with some sound deadening foam would really kill the noise.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Boon Docker
swimmer_spe wrote: jjrbus wrote: I find the dB ratings to be misleading, not useless. Some sounds within a rating can be more annoying. Then "quiet" generator is relative, A quiet Honda generator is quiet compared to an open frame construction generator. But hardly quiet.
That's funny and doubtful.
Honda 2000 - 57db
Champion 2000- 53 db
How can the Honda be quieter with a higher db rating?
wing_zealot
East of the Mississippi
I don't know what you mean by "Honda Quiet". Since Honda doesn't make a 3500 W generator, there is nothing to compare it to. So how many dB's do you consider to be "Honda Quiet"?
Secondly, are you looking for 3500 W surge or continuous?
At least for me, It's hard to be helpful when the parameters seem to be rather vague.
I'd also like to mention, that i thought dB measurenments for portable generators was always at 7 meters, at 1/4 load. That's the only dB ratings i ever recall seeing.
Latner
Indiana
Boon Docker wrote: swimmer_spe wrote: jjrbus wrote: I find the dB ratings to be misleading, not useless. Some sounds within a rating can be more annoying. Then "quiet" generator is relative, A quiet Honda generator is quiet compared to an open frame construction generator. But hardly quiet.
Honda 2000 - 57db
Honda @ rated load is 57, 1/4 load is 53. Champion only claims 53, probably 1/4 load but don't give @ rated load db.
