RV.Net Open Roads Forum: Tech Issues: Generator dB rating
 > Generator dB rating
Page of 5
Boon Docker
Posted: 05/16/23 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Latner wrote:
Boon Docker wrote:
swimmer_spe wrote:
jjrbus wrote:
I find the dB ratings to be misleading, not useless. Some sounds within a rating can be more annoying. Then "quiet" generator is relative, A quiet Honda generator is quiet compared to an open frame construction generator. But hardly quiet.
What I speak of is that.... You can carry on a conversation around the Honda ones.Good luck doing that to a Champion.
That's funny and doubtful.
Honda 2000 - 57db
Champion 2000- 53 db
How can the Honda be quieter with a higher db rating?
Honda @ rated load is 57, 1/4 load is 53. Champion only claims 53, probably 1/4 load but don't give @ rated load db.
Yep, the 53db is more than likely at 1/4 load. So they both have the same rating.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 05/16/23 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Honda 2000 - 57db
I have never seen any of the quiet Champion ones.
swimmer_spe
Posted: 05/16/23 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
wing_zealot wrote:
I don't know what you mean by "Honda Quiet". Since Honda doesn't make a 3500 W generator, there is nothing to compare it to. So how many dB's do you consider to be "Honda Quiet"?
Secondly, are you looking for 3500 W surge or continuous?
At least for me, It's hard to be helpful when the parameters seem to be rather vague.
I'd also like to mention, that i thought dB measurenments for portable generators was always at 7 meters, at 1/4 load. That's the only dB ratings i ever recall seeing.
What I want is 30A available at all times. That is the rating of my trailer. So, as I understand that works out to be about 3500-3800W
Even at full load, the smaller 3000W ones seem to be quiet in comparison to most others.
pianotuna
Regina, SK, Canada
Posted: 05/16/23 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Swimmer_spe
look for 80% of 30 amps for the continuous load. i.d. 24 amps.
For surge use a 'load support' inverter charger. I recommend Victron
Regards, Don
Boon Docker
Posted: 05/16/23 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
The db rating for the Honda 3000 is pretty good.
bikendan
Goodyear, Arizona
Posted: 05/16/23 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
o
Which Champion generator are you referring to? Open frame contractor-style or inverter generator?
Nearly every owner of a Champion inverter generator, that I've seen post on various RV forums, loves their Champion.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
valhalla360
No paticular place.
I've seen a variety of test conditions and many that just list a dB with no test conditions specified.
Even if you are right and it's always at 1/4 load, that can be misleading:
- 1/4 of of 4500w generator would be 1250w...in the ballpark of what you would be drawing with the air/con running.
- 1/4 of a 2000w generator would be 500w...you aren't running the air/con with 500w, so reality when running the air/con will be more like 2/3 load and typically much louder than the 1/4 load rating.
We found this to be very true when we switched from a 2400w Yamaha to 4500w Champion. At idle, the Yamaha sounds quieter but kick on the air/con and the Champion is clearly quieter. Also, there's no question it will kick the air/con compressor over with the bigger generator.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bikendan
Goodyear, Arizona
Posted: 05/16/23 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
Honda 2000 - 57db
Then you need to, before passing judgement.
swimmer_spe
Posted: 05/16/23 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
bikendan wrote:
swimmer_spe wrote:
Honda 2000 - 57db
Also, if you see my first post, it specifically asked for somewhere that compares them. So, I will wait for that before passing judgement.
swimmer_spe
Posted: 05/16/23 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
bikendan wrote:
swimmer_spe wrote:
o
The open frame ones. Here in Canada, I have yet to see any other style for them.
Page of 5
