RV.Net Open Roads Forum: Tech Issues: Generator dB rating
 > Generator dB rating
Page of 5
cptqueeg
Idaho
Posted: 05/17/23 08:20am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
cptqueeg
105 is without fuel and oil. My Yamaha is about 155 lbs. I built a box where the lid and side double as a ramp.
I know weight may or may not be a critical issue depending on setup.
JKJavelin
Milwaukee, WI
Posted: 05/17/23 11:10am Link  |  Quote  |  Print  |  Notify Moderator
In early 2018, I bought a Champion 3100/2800 gas only inverter generator. It's done a good enough job, though not as quiet as a Honda. This year I got tired of dealing with having gas around, especially the storage of it on the road, and found a great deal on the Champion 2500 dual fuel. So I just bought 2 of them along with a parallel kit. Weight was a factor also: 37 lbs vs 95 lbs. I intend to only use propane. They were $399 each and probably would only need the second one for A/C.
They are still in the boxes, will try them out soon.
I hope that they are quieter than the 3100
JK
* This post was edited 05/17/23 01:32pm by JKJavelin *
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
PatJ
Eastern WA
Posted: 05/19/23 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
duplicate
Patrick
PatJ
Eastern WA
Honda 2000 - 57db
Champion 2000- 53 db
How can the Honda be quieter with a higher db rating?
I own a pair of Honda 2000s. My sister owns a pair of Champions. The Champions are great but no contest, the Hondas are quieter. Quieter at idle, quieter at mid load, quieter at full load. Quieter by far and noticeable. My Hondas are 15 years old and have around 500 hours on them. Anyone that says they are close in volume to the Champions is lying or deaf (in my opinion.) Again nothing against the Champions because they seem to be very reliable and good bang for the buck, but they are not quieter or even as quiet or even close to the Hondas.
Posted: 05/19/23 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
^Yup. They’re just as good as Hondas until you understand that they aren’t.
pianotuna
Regina, SK, Canada
Posted: 05/20/23 11:02am Link  |  Quote  |  Print  |  Notify Moderator
PatJ wrote:
Honda 2000 - 57db
That depends on how deaf the owner is. I don't believe folks go out of their way to lie. They do have a right to an opinion.
Regards, Don
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 05/20/23 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
As I posted earlier most db rating are at X number of feet from the source. I think the Honda's are rated like at 25 feet, the Champion rating might be at say 50 feet.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
swimmer_spe
Sudbury, Ontario, Canada
Posted: 05/20/23 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Which is why I was looking for a comparison of them from some unbiased source.
Page of 5
